Front pads and rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TunnelDV, Jan 5, 2013.
  1. Jan 5, 2013 at 12:59 PM
    TunnelDV
    TunnelDV [OP] Well-Known Member
    Derek
    Denver
    10 4Dr Tacoma White
    Looking to replace front brake pads and rotors. I would prefer to upgrade a bit and get lighter rotors that can cool faster and pads that grip better. I'm ok if the pads don't last as long as OEM. Any suggestions?
    Derek V
  2. Jan 5, 2013 at 1:47 PM
    Fire Taco Fighter
    Fire Taco Fighter Well-Known Member
    trd
  3. Jan 5, 2013 at 1:53 PM
    TunnelDV
    Derek
    Denver
    10 4Dr Tacoma White
    Good price for pads and rotors, especially with free shipping. Unless someone has a better suggestion, I'll get those. Thanks!
    Derek V
  4. Jan 5, 2013 at 1:53 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I'm in the same boat, tag for responses
  5. Jan 5, 2013 at 3:24 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Don't do it! When it comes to brakes, I am hesitant to use the cheapest products. And our trucks don't need drilled rotors, unless you race, and if you did, you wouldn't want these.
    http://g35driver.com/forums/v36-bra...tive-ebay-drilled-slotted-rotor-review-3.html
    "The downside of using drilled rotors on your vehicle is that all of those holes tend to weaken the rotors -- just like punching holes in the wall of a house would weaken the wall. After repeated stressful driving, the rotors can even crack. "
    http://auto.howstuffworks.com/auto-parts/brakes/brake-parts/brake-rotors1.htm
    I have about 60K on EBC dimpled rotors. They are starting to shake ever so slightly at 50+mph but they still brake good and they are not eating my brake pads as slotted rotors tend to do.
    http://www.amazon.com/EBC-Brakes-GD...F8&qid=1357426679&sr=8-1&keywords=ebc+ GD7237
  6. Jan 5, 2013 at 3:43 PM
    TunnelDV
    Derek
    Denver
    10 4Dr Tacoma White
    Is that $173 for one rotor? Ouch
    Derek V
  7. Jan 5, 2013 at 3:50 PM
    Teton Tacoma
    Teton Tacoma Well-Known Member
    Wydaho
    2016 Off Road M/T
    I tow a boat over the infamous Teton Pass(10% grade for 6 miles) in the summer. I use Powerstop slotted and drilled rotors .Got both rotors and pads for $200 or so. They work great and have been for 3 summers.
  8. Jan 5, 2013 at 3:58 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    As far as brake pads go I have used Akebono ACT series pads for my truck. (Akebono makes the OEM brake pads for Toyota as well as other manufacturers OEM pads) I have had very good luck with these, no noise and minimal brake dust. Just my .02
  9. Jan 5, 2013 at 4:02 PM
    ManMan
    ManMan Well-Known Member
    House facades (brick/ sheetrock) are not load bearing, so drill away they won't be weakened unless you start cutting out the studs.
    Drilled and or slotted/dimpled rotors really only offer bling for a street vehicle and are more prone to cracking. Worst case, cheap drilled rotors might have drilled through support ribs. Cooling faster also means they heat up faster (less thermal mass) so they will fade easier. Light weight rotors assemblies come from a two piece rotor with a light weight hub. A little less unsprung mass but nothing you'll notice in a heavy street truck
    Real braking improvement comes from the pads. Get some Hawk LTS pads and call it a day. Replacement blank rotors if yours are shot. SS lines give more feel (but no more "power") if you want to spring for them.
  10. Jan 5, 2013 at 7:33 PM
    Chuy
    Lakeside, CA
    Silver Taco
  11. Jan 5, 2013 at 9:05 PM
    Fire Taco Fighter
    trd
    STOP!!!!!!!!!!!! I have had these rotors on my f150 for 3 years now w/ no problems at all these are the best brake I have ever had.......stopping distance has decreased they never warped.the ceramic pads are cleaner to........no more brake dust all over my wheels.
    These are excellent brakes.
  12. Jan 5, 2013 at 10:24 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I was looking into some brembo blanks, possibly slotted.
  13. Jan 6, 2013 at 12:09 AM
    leg killa
    leg killa Well-Known Member
    AMERICA
    06 SBDB SR5 4x4
    TRD Hood/ Color matched grill/ De badged/ BHLM/ Viper remote start/ Pioneer AVIC Z-130BT/ BFG MT KM2/ MT Classic II/ OME Lift/ LR UCAs/ Pop and Lock
    I use hawk pads. Very little brake dust, quiet and have been working well.
  14. Jan 6, 2013 at 12:13 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Hawk lts and brembo BLANK rotors.
    Slots may cause pulsing and may shorten pad life......drilled are prone to cracking
  15. Jan 12, 2013 at 10:17 PM
    moline
    moline Member
    torrance, ca
    11 dcab Pre/10 AC Pre
    I upgraded my 05 with akebono act pads and centric rotors. Huge difference.
    Planning to get akebonos and brembo rotors from tirerack.com for my 10 Pre (good reviews).
    Later
    Dan
