Front parking lights no worky
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black3144, Aug 24, 2011.
  1. Aug 24, 2011 at 7:43 PM
    Black3144
    Black3144 [OP] Well-Known Member
    Bellevue, NE
    '07 TRD Off Road
    Anyone have a problem with their front parking lights not working, but they work with the turn signal, hazards, and when you lock and unlock the truck. Just did the fog light mod a couple of weeks ago. I read in some of the other threads that if the rears work than the fuse and relay are good, not sure what the hell is up with mine.
    Anyone have a good wiring diagram for the lights???
  2. Aug 24, 2011 at 8:40 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    The lights you are talking a out don't come on with headlights. Only the small lights by the fenders come on with the headlights. If you have daytime running lights, the turn signal bulbs will be illuminated when the headlights are off & parking brake off.
  3. Aug 25, 2011 at 4:03 AM
    Black3144
    Bellevue, NE
    '07 TRD Off Road
    I'm talking about with the headlights off and the switch in the middle detent before you turn the headlights on, you should have you turn signal lights on steady. Also when I turn on my headlights the little lights on the outside don't turn on, all I have up front with the headlights on are my headlights.
  4. Aug 25, 2011 at 7:24 AM
    rufusleeking
    rufusleeking Member
    West Fargo, ND
    2009 Tacoma Double Cab (TRD Offroad)
    Are you talking about the corner lights on the front end, or those on the inside of the headlights? If it's the inside of the headlights, those are only for blinkering or hazards and that's the only time they turn on. The corners, those should come on solid with parking/headlights.
  5. Aug 25, 2011 at 10:30 AM
    Black3144
    Bellevue, NE
    '07 TRD Off Road
    Well I'm special, thought the inside one came on for parking lights. The outside ones are burnt out. Thanks for the help
