Front Parking Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlakTaco14, Nov 18, 2012.
  1. Nov 18, 2012 at 5:15 PM
    BlakTaco14
    BlakTaco14 [OP] New Member
    I have a 2005 Tacoma Prerunner and I can not get my front parking lights to work. I've checked bulbs, fuses and relays. I've tried researching this issue several times and I can not find what I'm looking for. :pccoffee:
    Anybody have any solutions or recommendations? Thanks in advance.
  2. Nov 18, 2012 at 5:17 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The ones on the corners, or the ones between the headlights and the grille?
    The ones between the headlights and the grille are ONLY turn signals on the 2005.
    Later models used them as DRLs... and they shut off when the headlights are turned on.
    The corner lights are the only front parking lights on any 2nd Gen Tacoma.
    Chadley22 likes this.
  3. Nov 18, 2012 at 8:06 PM
    BlakTaco14
    When I turn my parking lights on, I have no lights at all on the front of my truck, including the lights on the sides.
  4. Nov 18, 2012 at 8:26 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The bulbs are in sockets, and the sockets plug into the harness.
    Double check those connections, commonly overlooked.
    I'm not 100% positive, but there may be a second fuse for the front and rear lights. Check the panel under the dash.
    Rear parking lights work? That would indicate that the switch is okay.
  5. Nov 18, 2012 at 8:30 PM
    BlakTaco14
    The rear parking lights do work. It's just the front ones that I'm having some trouble with. I have checked the fuses under the hood and also under the dash and they all seem to be okay. I will take another look at it again tomorrow and check those connections again though.
  6. Nov 19, 2012 at 9:53 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Both of my Parking (Running Lights) bulbs were blown. I picked up a pack of Sylvania #2827 LL (Long Life) replacement bulbs. They look like fat yellow Christmas tree lights.
  7. Dec 4, 2012 at 10:07 PM
    yamabiker
    yamabiker Well-Known Member
    Utah
    2006 Double Cab SR5 TRD
    Was checking the front parking lights last night and noticed that neither worked??? Rear worked, signals worked. Pulled them to inspect and surprisingly both bulbs had broken filaments. Kind of odd. Replaced them and they are fine so far.
    Yamabiker
  8. Dec 4, 2012 at 10:11 PM
    tacofire38
    tacofire38 Captain Taco
    Land o Pears,TX
    08 Taco PreRunner SR5
    V-Tech gunmetalrims, BFG All-Terrains, Front 5100s and OME 884 coils, Rear 5160s, Rear AAL, SpiderTrax Wheel Spacers, Hummer Bed Rack, Thule Kayak Roof Racks........
    Same problem with me. How the hell do I get them out?!?!?
  9. Dec 5, 2012 at 6:34 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Reach in behind the headlight under the edge of the fender and you'll feel the socket.
    Give it a 1/4 turn and it'll pull right out.
  10. Feb 18, 2018 at 1:05 PM
    ShuggieTaco
    ShuggieTaco Well-Known Member
    2011 Tacoma
    1.5" level front
    Anyone ever had the issue where the parking light (very outside orange bulb) sometimes won’t come on? It’s just the passenger side. If it’s not on I can bump the corner of the headlight assembly and it’ll light up. What’s the problem??
  11. Feb 18, 2018 at 10:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Bulb with a loose connection in the socket. The bulb could be damaged also.
  12. Feb 19, 2018 at 4:17 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Take a small screwdriver and pry the tabs in the socket to the center of the socket. All 4 tabs..
  13. Feb 19, 2018 at 4:33 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    **with vehicle and lights off**
    Never know these days :) lol
  14. Feb 19, 2018 at 4:48 AM
    Larzzzz
    Larry
    MA
    I suppose. Being an electrician, I know not to go across the terminals... The only way I can describe it would be to imagine your index and middle finger being the terminals for one side of the light bulb and your arm being its wire. Take the screwdriver and pry your fingers together as it were in the socket
  15. Jan 17, 2023 at 1:31 PM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    when/how does this light turn on and off?
  16. Jan 17, 2023 at 3:28 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    electrons flow through the filament once directed by the operator via a switch. electricity enters and heats the tungsten filament housed inside. And when the filament heats up, “incandescence” is created, which is light produced by heat
    Jimmyh likes this.
  17. Jan 17, 2023 at 3:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    So the current flows from Positive side of the battery, to the negative side.
    And the electrons go from the negative side to the positive side. Makes perfect sense.:boink:
    Jimmyh likes this.
  18. Jan 17, 2023 at 3:50 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    mr franklin had an incorrect assumption way back when. Probably that lightning strike that killed a few brain cells.
    Jimmyh and TnShooter[QUOTED] like this.
