front parking lights
Discussion in 'Lighting' started by skizzler7, Jan 1, 2013.
  1. Jan 1, 2013 at 7:19 AM
    skizzler7
    skizzler7 [OP] Member
    Bill
    Pennsylvania
    08 extended cab
    08 tacoma parking lights won't come on. The 4 ways and turn signals work fine. The rear lights are fine also
    Anyone have any experience with this problem?
  2. Jan 5, 2013 at 12:17 PM
    iamsuperbleeder
    iamsuperbleeder Licensed Lunatic
    Travis
    Lake City, Florida
    06 DC Prerunner Taco - SOLD -
    TRD E-locker rear axle swap, Cherrybomb Extreme muffler, custom made CAI, 2.5" spacer lift up front and AAL's in the rear, Sport model seat swap, Pioneer X940BT, Kicker shallow 10" and 12" behind the back seat
    try replacing the bulbs? they do burn out
    just a thought...
  3. Jan 6, 2013 at 4:40 AM
    skizzler7
    Bill
    Pennsylvania
    08 extended cab
    I'll take a look at them. Thanks for the input.
  4. Jan 6, 2013 at 5:19 AM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Usually not in pairs. Check the fuse, might have a short somewhere.
  5. Jan 6, 2013 at 7:00 AM
    iamsuperbleeder
    Travis
    Lake City, Florida
    you're right usually not, but I have had one burn out, never bothered to replace it, and had the other burn out later. thus why I replace bulbs like that in pairs any time just one burns out
  6. Jan 6, 2013 at 12:15 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Replace them with leds. Last longer and looks better.
  7. Jan 15, 2013 at 3:00 AM
    Syntonization
    Syntonization tAKoma Godfather
    Jeremiah
    Anchorage, AK
    09' TRD Sport dbl cab long bed
    Cooper Discoverer ST MAXX 295/70/17. Tuff Wheels 17x8 -13 Offset. Front Suspension: Fox Racing 2.5 Series Extended travel shocks w/ Eibach coil-overs, Total Chaos UCA's. Rear: Dakar Leaf Springs, Fox Racing 2.5 Series Long travel shocks. Superbump Stops. Cab mount frame chop. BruteFab frame sliders. Pelfreybuilt Front bumper, Hi-Clearance Rear w/swingarm and table. Color matched BRM! Superwinch Tigershark TS9500 SR. Morimoto 5Five FX-R Stage III HID Projector retrofit 6000K. Rigid DOT Fog lights, 20" light bar, dually ditch lights. 6500 lm LED underbody rock lights. Fog lights on any time MOD. K&N 77 Cold Air Intake. Flowmaster American Thunder CAT back dual exhaust. CompuStar 2 way remote start w/ 2 stage alarm and keyless entry. White under hood LED strip lighting, with automatic hood pin on/off switch. Dynamat & Dynaliner sound deadening in doors & cab. Kenwood DDX574BH Head unit with Maestro OBDII interface. Rockford Fosgate Punch 5 ch amp with Punch Component tweeters, woofers & sub. USB charging/data ports in blank plug under head unit. Instrument cluster, red and white LED's replacement. Backlit 4x4 selector switch. Anytime on/off Rear-view mirror back up camera. Uniden PRO520XL CB w/ co phased ATT's. Toyota Hood Protector. Coverking Neoprene black w/ red center seat covers. Color matched Devil Horns grill emblem.
    Have you found a problem/solution yet?
    If not, when you say "parking lights" do you mean the dtrl?
  8. Jan 15, 2013 at 4:57 AM
    skizzler7
    Bill
    Pennsylvania
    08 extended cab
    found that they were both burned out. was confused as to where they were. I originally thought that they were towards the middle, but they are on the extreme outer edges. thanks for your thoughts.
  9. Jan 22, 2013 at 4:42 PM
    TacoWill
    TacoWill Active Member
    will
    Sudbury, MA
    2008 Access cab, cab,6cyl. 4x4
    BackRack, bed extender, hitch, bed mat, Pop and Lock, WeatherTech mats
    I would like to make my fogs into DTRL. Anybody done this?
  10. Jan 22, 2013 at 4:56 PM
    iamsuperbleeder
    Travis
    Lake City, Florida
    you're welcome :D
  11. Feb 7, 2013 at 7:24 AM
    emt49126
    emt49126 Active Member
    Rodney
    Kentucky
    Tacoma
    My two have gone out. Replaced both bulbs yesterday. No luck. The turning signal works just fine. Fuse not blown. Guessing maybe a short??
  12. Feb 7, 2013 at 9:39 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Doing the fog light anytime mod will allow you to control when dtrls are on or off
  13. Feb 7, 2013 at 4:20 PM
    iamsuperbleeder
    Travis
    Lake City, Florida
    are the rear running lights working?
  14. Aug 18, 2013 at 9:15 AM
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    What bulbs did you replace them with? I just pulled mine out but see no bulb size on them
  15. Aug 18, 2013 at 10:07 AM
    jlleiber
    Justin
    Indiana
    Answered my own question - sylvania 2827 is the correct size
  16. Aug 18, 2013 at 4:51 PM
    csjumper2003
    Savannah, GA
    There are a lot of number for those replacements, but the most common is a 194, or 168
  17. Aug 19, 2013 at 11:31 AM
    iamsuperbleeder
    Travis
    Lake City, Florida
    168 being common for exterior; brighter and burn hotter, don't last as long though; higher wattage
    194 is typically used for interior lighting; not as bright and doesn't get quite as hot, will last a little longer; lower wattage
