Front Passenger Window Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Old&fat, Oct 21, 2021.
  1. Oct 21, 2021 at 10:56 AM
    Old&fat
    Old&fat [OP] Well-Known Member
    21 TRD offroad
    I'm having trouble with my front passenger window. Last night I installed an OEM automatic tailgate lock. The lock works fine, but now I'm having front passenger side window problems. From the driver side controls, the window doesn't work. But from the passenger side controls it works just fine. Everything else in the door works, too; mirrors, speakers and locks. The fuses under the steering wheel check out, any ideas? Is there another hidden fuse? Fwiw, the toyota app keeps telling me the window is down when it's not. I posted this earlier in another thread without realizing it was in the 2nd gen forums. Figured I'd try over here. This is a 2021 TRD offroad. Thanks!
  2. Oct 21, 2021 at 10:59 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Try this, not sure if it works on our trucks, but its a quick thing to try
  3. Oct 21, 2021 at 12:22 PM
    Old&fat
    21 TRD offroad
    Hot damn that actually worked!!! Thank you!!!
    5nahalf[QUOTED] likes this.
  4. Oct 21, 2021 at 12:23 PM
    5nahalf
    Erik
    Minnesota
    Wooohoo! Quick easy fix.
    EDIT: I just looked at your thread in the 2nd gen forum.... they were asking you to do all sorts of taking apart and checking before even trying the easy stuff first.
    shakerhood likes this.
  5. Oct 21, 2021 at 12:46 PM
    Old&fat
    21 TRD offroad
    I actually just tagged onto someone else's window problems hoping to not start a new thread. I dont think my question has gotten a reply yet. Anyway, I didnt unplug the battery when I did the Install. I wonder if that would have reset the windows too.
  6. Oct 21, 2021 at 12:51 PM
    5nahalf
    Erik
    Minnesota
    Could of caused the issue, but I will say I have done so many things that should of needed the battery disconnected, but had no issues. Some people do some dont. But always good practice you unhook battery when doing electrical.
  7. Mar 21, 2022 at 4:47 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Thanks for this posting! After messing up my window controls, this video/fix worked to reset them! :thumbsup:
  8. Mar 21, 2022 at 5:01 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    The search actually works! :thumbsup:
  9. Mar 21, 2022 at 5:06 PM
    RyanDCLB
    4/19 DCLBOR
    Yup! Sorry to all those folks I bothered before using the search feature. ;)
  10. Mar 21, 2022 at 5:10 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Same haha
  11. Mar 21, 2022 at 5:12 PM
    RyanDCLB
    4/19 DCLBOR
    If you turn on the ignition when one window control is not plugged in, then it will trick the master (driver) control into thinking it's not there. Very tricky these Toyotas. If anything, watch the video for the laidback commentary. :rofl:
    Rainoffire and Skydvrr[QUOTED] like this.
  12. Mar 21, 2022 at 8:10 PM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Glad everything worked out!
  13. Jun 24, 2022 at 6:57 PM
    CAtacoWaves
    CAtacoWaves Active Member
    2019 MT DCSB OR
    Rhino Rack Gutter Channels & Rack, Thule Bed Rack (old model mod), Bed Platform,[Switches: Stereo Brightness, NAV Bypass, White Noise Backup Alarm], Interior AC plugs w/400W anytime, Gate King, Bed & Underhood Lights, SPIKER Eng Hood Struts, MICTUNING Tailgate Light Bar, Blinker Genie 2 Mod for side mirrors and side markers. CBI 0deg Rock Rails, Riccochet Al Full Skids, Bed Divider Rear Window Block, Rostra Front Rock Crawl Camera, Rostra Front/Rear Dashcams, [Alarm Upgrades: Glass Break Sensor, and Tilt Sensor, Shock Sensor, Tailgate Sensor with off switches]. Snail Armor Tailgate Insert. Pop&Lock Tailgate Lock. SaBellCo Tailgate Security Lock. Wheeler's OR 1.5" Prog Add-a-leaf with stock Overload spring. TIMBREN Active OR Rear Bump Stops. FOB free key. HitchSafe. TUFFY Lock Boxes in Center Console & Rear Seat. Toyota Wheel and Spare Tire Locks. In progress: Bilstein 5100s & OME 886 coils, Durobumps Front Bumpstops, CBI hidden front hitch, Hitch mounted winch with front and rear wiring, Eco Gapshield, War Fab Inc Sheridan Hitch Skid, Battery Upgrade. Make me stop...
    You’re a lifesaver! I had removed my 2019 Tacoma door panels (for MESO puddle lights install) and afterwards couldn’t work the passenger side window from the driver side, even though the passenger side worked. Auto up/down stopped working too. I don’t know how I tripped it up, but I was disconnecting the battery multiple times while doing electrical work. I had given up, found this, and it did the trick. Thanks!
  14. Mar 15, 2024 at 10:40 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    Just wanted to chime in and say this worked for my 2019 I just bought. Passenger window wouldn’t roll up with the drivers side button. Quick reset and it fixed it.
  15. Mar 26, 2024 at 4:51 PM
    Sheppington
    Sheppington Active Member
    2016 Inferno Tacoma TRD OR 6spd Manual DCSB
    Excellent find, my 2016 OR battery died after I left the radio on sitting for an hour or two and after jump starting I noticed the auto function on the window switches drivers side weren't working, also lost control of the passenger window only from driver's side
    Fearing that I smoked something jump starting, I panicked and found this, worked like a charm, had to reset the drivers and passenger side.
    Many thanks!!
  16. Nov 21, 2024 at 4:15 PM
    Raul4431
    Raul4431 Active Member
    Raul
    Concord, NC
    2021 Black Tacoma TRD PRO
    Worked on Tacoma 2021, same problem. I pulled the fuse and putting it back didnt fix the issue this video did. Life saver thank you !
