Front Range Offroad Twin stick shifter for 95.5-04 tacoma.
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by 98tacoma3rz, Mar 3, 2018.
  1. Mar 3, 2018 at 3:49 AM
    98tacoma3rz
    98tacoma3rz [OP] Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
  2. Mar 3, 2018 at 8:28 AM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Excuse my newb question but what exactly does this do?
  3. Mar 3, 2018 at 8:30 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    It allows you to shift the transfer case in 2lo.
  4. Mar 3, 2018 at 8:33 AM
    1st4x4
    sam
    Torrance
    So this makes it to where the truck has 2 low 2 hi 4 low and 4 hi?
  5. Mar 3, 2018 at 8:35 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
  6. Mar 3, 2018 at 9:54 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    When would you use 2LO?
  7. Mar 3, 2018 at 11:04 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    A lot when you're rawling down trails. Slow driving, locked rear. Much easier to turn. Less strain on 4x4 system. Also works good if you have a "lunch box" type locker in the front. Disengage front diff to turn when in 4x4.
  8. Mar 3, 2018 at 3:13 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    I believe just high or low and 2wd or 4wd
  9. Mar 3, 2018 at 9:41 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I drove with FWD for a good two weeks while I had my driveshaft at a machine shop. It's not fun.
    JasonLee, SnowroxKT and Jon64l like this.
  10. Mar 7, 2018 at 8:44 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I’d be interested but it looks like the transfer case shifter moves location with these?
  11. Mar 7, 2018 at 8:45 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Not sure. Comes with rubber boots.
  12. Mar 7, 2018 at 9:42 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    No rear driveshaft and the transfer case in 4HI. Had it like that for a while because my rear driveshaft was in the machine shop.
  13. Mar 7, 2018 at 9:49 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Not too different from standard RWD but the truck handled differently and braked differently.
  14. Mar 8, 2018 at 11:36 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Nice sale thread jacking. Let the OP sell their twin stick and start a conversation, @Jamesboy2233
    Adude and Running Board Man like this.
  15. Mar 10, 2018 at 10:11 PM
    ZrowGz
    ZrowGz I'm a n00b.
    SLC, UT
    97 4x4 LT/Cantilever
    Interesting piece of equipment. I never even thought of such a thing. Does it just bolt right on and you're done or what's the install like?
  16. Mar 10, 2018 at 10:13 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Nah you have to remove a ball bearing that acts as a detent from the case before you can actuated the levers separately. Simple job but the case has to come off.
  17. Mar 10, 2018 at 10:15 PM
    JasonLee
    15 TRD OffRoad
    "Q: What’s involved in the modification to the transfer case?
    A: You must drain and remove the transfer case from the vehicle. Once removed, the modification takes at most 45 minutes. You must remove the Interlock Pin. This pin keeps the 2 shift rails from sliding independently and engaging two-wheel drive, low range. It requires only a couple wrenches, hammer, and a small punch. The procedure is described in the detailed instructions."
    "steange1 (Submitted on 16th May 2015)
    This is a very well built shifter, and installs into a Tacoma easily. I had to grind the shift rail with it in the case because to remove the rail would mean a complete disassembly of the case. No big deal, but the instructions were a bit unclear."
    All information is from the product page linked by the OP. Here's the link again in case you missed it. https://frontrangeoffroadfab.com/twin-stick/
  18. Mar 10, 2018 at 10:21 PM
    ZrowGz
    ZrowGz I'm a n00b.
    SLC, UT
    Totally missed it, lol, must be bedtime. Thanks!
  19. Mar 11, 2018 at 6:44 AM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    FYI it's an irreversible mod. I have one and it requires cutting/grinding off a piece of the shift rails. More than just removing the "pill" piece at the back. I enjoy mine for when I want lower gears but still enjoy a tight turning radius because 2wd.
    Adude likes this.
  20. Apr 15, 2018 at 4:36 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Still available!
    Wulf and Running Board Man like this.
