Front & Rear Differential Factory Fill Low
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MA250, Nov 30, 2019.
  1. Dec 8, 2019 at 10:43 AM
    #81
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
  2. Dec 8, 2019 at 10:43 AM
    #82
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The spec is pretty generous, +/- 5mm of the fill hole level. 5mm depth over the entire width of the axle tube can be quite a bit. Spec has been that way for the last 15 years. It has a negligible effect on cooling the rear diff. That's about it. The smoothness you perceived (assuming it isn't placebo effect) would be from the better Redline fluid, not from the fluid level.
  3. Dec 8, 2019 at 10:45 AM
    #83
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Unless the truck has been sitting on the lot, then bits and pieces will stick to creases (like around emblems). First hand experience.
  4. Jun 21, 2023 at 2:55 PM
    #84
    soggyBottom
    soggyBottom Well-Known Member
    The rear in my My 2018 TRD pro with 40k miles on it was about 1qt low. The fluid that came out looked practically new. I'm draining the front right now and it looks way dirtier.
    CrashZone likes this.
  5. May 24, 2024 at 9:38 AM
    #85
    CrashZone
    CrashZone Well-Known Member
    My 2021 2.7 was 1 quart low at 27k miles as well. Put just less than 4 qts back in before it started coming out the fill hole. Fluid didn't look that great, at least compared to new, and magnet was covered in fine particles. Has me questioning all fluid levels from the factory at this point.
  6. May 24, 2024 at 9:39 AM
    #86
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    My 2.7L early 3rd gen came from the factory almost 1qt low in the rear diff too
    CrashZone[QUOTED] likes this.
  7. May 24, 2024 at 9:44 AM
    #87
    Pungo1
    Pungo1 Well-Known Member
    Mark
    I keep seeing these comments and that's exactly why I'm going to drain/fill my front/rear at 15K. Saving the transfer case until 30K. There's a lot of people on this forum who say under fills from the factory just never happen and we're all smoking crack. Makes me wonder about other fluid levels from the factory.....you know.....like A/T fluid?
  8. May 24, 2024 at 12:43 PM
    #88
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Fluids are cheap.
    Change the engine, oil, differentials, and transfer case early
