Front/Rear/Transfer Case service question
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Nov 19, 2015.
  1. Nov 19, 2015 at 8:40 AM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Trying to see if its recommended to service/change my front/rear/transfer case differential oil or not. Last time I did these 3 was at 50000 miles. I currently have 109000 on my 2002 Tacoma. I don't tow nor had I ever did before. Not sure if these service should be kept up regularly or not like an oil change. I know any oil will breakdown over time. Just trying to do some preventative maintenance while I have some time off work. Thanks.
  2. Nov 19, 2015 at 9:23 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I check mine twice a year, if it looks really nasty, I change it, if not keep driving!
  3. Nov 19, 2015 at 9:24 AM
    sirsaechao
    Tim
    CA
    Okay I'll check it and see how the fluid is and go from there.
  4. Nov 19, 2015 at 9:40 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Change the rear diff oil for sure. You are way over the 30k interval already. Rear diff sees a severe heat cycle every time you drive, so the oil breaks down faster. You know the rule of thumb where rwhp is about 20% less than flywheel hp due to driveline losses? About 15% is lost in the rear diff due to high friction in the hypoid ring-&-pinion gearset. At full throttle, 15% of 190 hp is 28 hp -> 21,000W heat being dumped into the oil... which does not have a filter or a radiator.
    Lt_Dan likes this.
