Front receiver
Discussion in '1st Gen. Tacomas (1995-2004)' started by brianhartjr, Dec 14, 2017.
  1. Dec 14, 2017 at 11:52 AM
    brianhartjr
    brianhartjr [OP] Active Member
    Brian
    1996 4x4 lifted Tacoma
    3" lift
    Just bought my first truck. 1996 3.4 liter. Want to install a front receiver so I can use a winch, any suggestions on which one will fit?
  2. Dec 14, 2017 at 11:55 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Do you want just a receiver or a metal bumper that can house a winch? If you just want a receiver I think there are a few out there that you can modify the stock bumper to fit with. If you want the cheapest alternative for a metal bumper, check the Trail Gear Rock Defense - the cheapest price is around $550 free shipping from Jegs.
  3. Dec 14, 2017 at 12:26 PM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I think Curt makes a front receiver hitch for your truck.
  4. Dec 23, 2017 at 7:34 PM
    turnerk1
    turnerk1 Well-Known Member
    Keith
    1996 4X X-Cab
    Mystery Lift
    I got a Warn 33025 the other day and am liking the fit. All holes line up nicely. Having a heck of a time bolting it up though. The instructions say use factory fasteners where the tie downs used to be. Don't have those. 12 mm is too small, 14 mm too big. Is is possible there's SAE fittings on my truck? The hitch will mount OK with 12 mm bolts running completely through the frame, top to bottom, but I'd prefer torquing it down frame to hitch plate. Also, I very slightly drilled out the back mounting holes that run horizontal through the frame to fit a 10 mm 10.9 grade bolt. I also used a galvanized backing plate with 1/2 hole against the inside of the frame to keep it from deforming. All this is to fit a Superwinch 3,000 lb ATV winch either front or rear for some light retrieval options.
  5. Dec 24, 2017 at 4:42 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    turnerk1 likes this.
  6. Dec 24, 2017 at 5:53 AM
    west467
    west467 Well-Known Member
    Two Black Tacos..03 and 09
    This is your cheapest way to go...
    https://www.curtmfg.com
  7. Dec 24, 2017 at 11:38 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Friends that fabricate can make one pretty cheap
    I know I can
  8. Dec 24, 2017 at 12:44 PM
    west467
    Cheaper than $119.99???
  9. Dec 24, 2017 at 5:26 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Very easy to beat that price. I know I have drops paid for from past jobs.
    A few holes drilled a little welding
    Like I said friends that are not charging you a regular rate
