Front Recovery Points?
Discussion in 'Off-Roading & Trails' started by hfrank007, Feb 5, 2011.
  1. Feb 5, 2011 at 9:26 AM
    hfrank007
    hfrank007 [OP] New Member
    Denver, CO
    '09 Tacoma TRD Sport
    I've a 2009 Tacoma TRD Sport and am about to drive to Alaska. Just ordered a set of chains. Am now educating myself on vehicle recovery. Will buy a strap and a receiver hitch D Ring shackle with ring and pin.
    I've been searching forums and not finding an clear answer to this question:
    Is the ring (under the bumper) on the drivers side of the vehicle (I spotted) an attachment for someone's recovery strap should I (shudder) need to be pulled out? If not, where's the best place for them to attach a strap on the front?
    Thanks!
  2. Feb 5, 2011 at 10:16 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Ya, it'll work. Just get another shackle if its not the hook. I've got the hitch receiver shackle and its a must have!
  3. Feb 5, 2011 at 10:47 AM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    I'm not that knowledgeable about it, but..........
    from what I've read here:
    The driver's side recovery point is welded and questionable to some.
    The alternative is to buy the Recovery Hook, for an absorbident price,
    (Standard on the "TRD Off Road") to replace the "Tie Down Eye" on the passengers side.
    Toyota Part #51961-35080
    I believe it requires also purchasing a couple longer bolts to replace the "Tie Down" bolts
    Can be found here:
    http://www.toyotapartszone.com/oem/toyota~hook~no~1~51961-35080.html
    But you might Google it first.
    Also Search this site for more info. I know there's a thread or two about it
    Also at the "Other Site" here:
    http://www.toyotanation.com/forum/showthread.php?p=2197642#post2197642
    I'll post again if I find more info.
    Pictured below, I think this installation is reversed and the hook normally is open to the center of the truck.
    Good luck and enjoy Alaska
  4. Feb 5, 2011 at 11:07 AM
    Cape Codder
    Jack
  5. Feb 5, 2011 at 11:15 AM
    Bsly862
    Bsly862 Well-Known Member
    Nate
    Denver, CO
    08 Off Road
    3in lift
    Yeah to my knowledge that loop on the driver side is used just meant to be used as a tie down for when the vehicle gets transported.
    So you are going to want to get a hook like Cape Codder has shown ^^^
  6. Feb 5, 2011 at 11:25 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    I've seen the driverside loop nearly torn off. The metal its welded to is pretty thin and tears with a good tug. It'll work for a basic recovery, but if you're pretty buried I wouldn't trust it.
  7. Feb 5, 2011 at 11:39 AM
    Cape Codder
    Jack
    Passenger's Side: Tie Down
    Driver's Side: Recovery/Tow, but questionable
  8. Feb 5, 2011 at 11:45 AM
    RelentlessFab
    Eric
    :laugh: I've been thinking about it. ;)
  9. Feb 5, 2011 at 11:47 AM
    mustangwilly
    mustangwilly Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
  10. Feb 5, 2011 at 11:58 AM
    Ccwahoo
    Ccwahoo "The Emblem of a Free Man is a Gun"
    Central Virginia
    '10 TRD Sport 4x4
    You could give them out with a purchase of any product :wave:
