FRONT RECOVERY
Discussion in '1st Gen. Tacomas (1995-2004)' started by RESSIKANFLAUTIST, Jun 3, 2025.
  1. Jun 3, 2025 at 10:58 AM
    RESSIKANFLAUTIST
    RESSIKANFLAUTIST [OP] Member
    where's the reasonable D ring recovery point for a 95-04 first gen? does this exist? having trouble finding it
    first owner removed the bull bar and forgot to replace the original tow hook, lost contact with him
    can just go with this: https://www.ebay.com/itm/1864379909...YNC54WVUEe0j-njT47Zp6VP-Dkf-xWhEaAuJyEALw_wcB
    but i'd like something slimmer if possible
    seems crazy to me that i cant find something like this that fits an 04: https://www.bpfabricating.com/colle...23-hd-tacoma-recovery-tow-hook-passenger-side
  2. Jun 3, 2025 at 11:42 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    In addition to the hook (5196135051), there are two bent plates (5196335070 RH 5196435050 LH) that go up there as well.
    bolts for the RH: 9164281265
    LH: 9164281235
    No idea why that ebay hook is so expensive. MSRP is ~$130 for the hook, and the RH bolts are a few bucks a piece... And you can get them cheaper than that if you order online from a dealer... I'd stay away from ebay in general.
    If you were really concerned that those OEM parts aren't strong enough, get in touch with someone like @Kwikvette and see if he can cut and bend a thicker plate for you.
    those part numbers are from the SUSPENSION CROSSMEMBER & UNDER COVER parts page, if you're looking.
    Kwikvette likes this.
  3. Jun 3, 2025 at 11:56 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    That OE hook has been known to snap. Not so much being weak just that a strap tends to work it's way to the tip of the hook. That increased leverage seems to cause the failure (at the tip).
    The basic "tow hook" sold everywhere will bolt up to both sides and can be had with a retaining clip to keep a slack strap from falling off.
    https://www.autozone.com/trailer-hi...0lbs-tow-hook/1277023_0_0?searchText=tow+hook
    https://www.autozone.com/trailer-hi...h-spring-clip/1325997_0_0?searchText=tow+hook
    The supplied bolts are not metric and will not work on the Taco frame.
  4. Jun 3, 2025 at 11:58 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thanks for the tag Andy!
    I remember my own 1st Gen having one hook and one loop although I always remember those as being used for tie downs only right?
    Seems like a thicker steel plate is in order, similar to the factory loop while using stronger hardware as well.
  5. Jun 3, 2025 at 1:31 PM
    RESSIKANFLAUTIST
    wow yeah i'll take 9.99, im not a freak about it being original....and im not out wheeling so i dont anticipate much use, but putting on a light bar on so figured i might as well put a hook under there since im taking it all apart anyways
    but those holes will align? i have the factory bolts...
  6. Jun 3, 2025 at 2:30 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yes, I have one on each side. Amazing thing is I paid $10 each 25 years ago.
    And like I mentioned, they are sold everywhere, parts houses, Lowes/Home Depot, Harbor Freight etc.
