Front right axle seal installation?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dwalker001402, Apr 6, 2017.
  1. Apr 6, 2017 at 1:51 PM
    Dwalker001402
    Dwalker001402 [OP] New Member
    David
    2003 toyota tacoma
    I recently changed my front right axle and had to also change the seal, do to leaking after we got done. So now their is a new seal and its still leaking.. How far do you drive the seal into the diff.? Go till she stops, as we did, or flush to the out side with lips?
  2. Apr 6, 2017 at 5:47 PM
    02 quadcab
    02 quadcab Well-Known Member
    I put mine flush. I used a PVC 2 inch pipe connector to hammer it in without damage. Then i put a little oil on the seal and put the axle back in. Carefull not to damage it with the axle while installing.
  3. Apr 6, 2017 at 5:52 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Only go flush!!! I had to replace mine like 5x before I got it
  4. Apr 6, 2017 at 5:57 PM
    Dwalker001402
    David
    2003 toyota tacoma
    Okay thank you ill try it out this sunday! Hope it is the last time I have to take the front end apart lol
  5. Apr 6, 2017 at 6:03 PM
    anthony250f
    Anthony
    San Diego, CA
    Make sure you install it with the correct side facing out
  6. Apr 7, 2017 at 12:26 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This video has some good info on replacing both seals:
  7. Apr 7, 2017 at 1:15 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Dalandser likes this.
  8. Apr 7, 2017 at 1:31 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  9. Apr 7, 2017 at 7:19 AM
    anthony250f
    Anthony
    San Diego, CA
    It's pretty easy but very heavy. Try every angle till it comes out lol
    Dalandser[QUOTED] likes this.
  10. Apr 7, 2017 at 8:25 AM
    Timmah!
    TIM
    No plans to replace a front differential. I bet if you do a Google search, you'll find a good write-up or even a video on one of the many Toyota forums or YouTube.
    I imagine we might do this at some point if somebody finds an e-locker rearend on a wrecked Tacoma or 4runner at a Pick and Pull and then decide to grab the front differential at the same time so they don't have to deal with regearing the front. The way I understand it, the open differential gearing is 4.10 but the locker rear ends came with 4.30 gearing. So, if you want to swap out your open diff rearend with a locker rearend, you have to address the gearing in the front to match the rear.
