Front Right Side Squeak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Em3rtr, Jan 28, 2025.
  1. Jan 28, 2025 at 2:14 PM
    Em3rtr
    Em3rtr [OP] Member
    Emily
    2020 Tacoma SR5 4x4
    2” leveling kit
    I just recently put a little bit bigger tires on my truck. Went from 265/75/r16 to 285s. Now my front right is constantly squeaking when I’m not on completely level road. What do I need to do to fix it? The sound is driving me nuts lol
  2. Jan 28, 2025 at 2:28 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Did you install a lift? Or are you saying you took off the old tires, changed nothing else, and put on the new tires?
  3. Jan 28, 2025 at 3:08 PM
    Em3rtr
    Em3rtr [OP] Member
    Emily
    2020 Tacoma SR5 4x4
    2” leveling kit
    It already had a 2” leveling kit on it when I got it. So nothing was changed except the tires.
  4. Jan 28, 2025 at 3:16 PM
    YF_Ryan
    Kent, WA
    Have you checked to see if your tire is rubbing on anything? You might see clean/rub spot on the upper control arm. The added width of the 285 could make it rub.
    Random pic stolen from TacomaWorld, where this guy said his 275s were rubbing the control arm.
    Edit/Addition: Does the sound change with speed, or is it correlated more with bumps in the road.
    Chew likes this.
  5. Jan 28, 2025 at 3:21 PM
    Em3rtr
    Em3rtr [OP] Member
    Emily
    2020 Tacoma SR5 4x4
    2” leveling kit
    I’ll take a look. Not sure how I’d fix that if that were the case. And it only does it with bumps in the road. It makes a sound like something needs grease added to it.
  6. Jan 28, 2025 at 3:29 PM
    YF_Ryan
    Kent, WA
    If it were the tire rubbing, you'd need wheels with additional offset, or a spacer, to get the tire further from the control arm. As the suspension cycles, the angle could change enough to rub only intermittently.
    If it's suspension squeak, which honestly sounds more likely, the best thing might be to start with someone bouncing the front corner of the truck as hard as possible and see if you hear the squeak, and if you do, climb under and see if you can pinpoint where it's coming from. I'd also suggest bouncing the rear as well, as I've heard some folks ended up having a squeaky leaf spring that they swore was coming from the front. Sometimes it's just hard to tell where the sound is coming from.
    I had a squeak for ages before I finally found out my sway bar linkage wasn't tight on the spindle. Only when the truck was PERFECTLY level was the tension on the sway bar released enough that I could feel with my hand that it was slightly loose. I even changed my radiator support bushings out hoping that was the issue before I figured it out.
  7. Jan 28, 2025 at 3:41 PM
    Em3rtr
    Em3rtr [OP] Member
    Emily
    2020 Tacoma SR5 4x4
    2” leveling kit
    thank you! I’ll give all this a try. I appreciate the suggestions
    YF_Ryan[QUOTED] likes this.
