Front right wheel squeel when warm and reversing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by townie, Aug 9, 2013.
  1. Aug 9, 2013 at 8:19 AM
    townie
    townie [OP] Member
    townie
    St. John's
    02 Tacoma double cab 4wd V6 3.4 Black - sandstone or something.
    New Chassis installed by dealer Dec. 2016.
    My 2002 Tacoma 4wd double cab automatic, just turned 100,000 km. After I drive for 20kms or more,I hear a squeeling noise when I back in the driveway.Do not happen in forward. Igot out and rocked the front right wheelback and forth and could hear a squeek on every movement. After a few minutes when the area cooled off the squeeling stopped. It seems to come from inside the FRront right wheel center. Any ideas what it could be? Hopefully its not costly formy retired income. Any or suggestions is much appreciated. :rolleyes:
  2. Aug 9, 2013 at 8:21 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    warped rotor? how long since brakes replaced, and does the wheel shimmy a bit when stopping hard?
  3. Aug 9, 2013 at 8:47 AM
    townie
    townie [OP] Member
    townie
    St. John's
    new brakes and rotors were installed about 6 months ago. No notice of shimmy when stopping hard
  4. Aug 9, 2013 at 11:16 AM
    Coast2Coast
    Coast2Coast Well-Known Member
    Northern Alberta
    2009 TRDOR
    Black Sand Pearl factory paint - flattened "au natural" by tree branches.
    Bad wheel bearing possibly? Try jacking the wheel off the ground, grab the top and bottom of the wheel, shake, if theres play in the hub the bearing is toast.
  5. Aug 10, 2013 at 4:53 AM
    townie
    townie [OP] Member
    townie
    St. John's
    I will check the wheel for play.
    As for the dust cover issue, I did have a scraping issue before with the front left wheel,The dust cover was contacting. I just bent it back, will also check the clearance when I jack it up and check for bearing play. Thanks all
  6. Aug 10, 2013 at 5:00 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    That type of noise can sometimes be caused by a rock or other object caught between the rotor an backing plate. Why it only happens when the vehicle is"warm" I have no clue.
  7. Aug 10, 2013 at 5:33 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Hanging caliper?
  8. Aug 10, 2013 at 7:52 AM
    Coast2Coast
    Northern Alberta
    2009 TRDOR
    ^This too, I got this alot with my other 09.
  9. Aug 11, 2013 at 4:08 PM
    townie
    townie [OP] Member
    townie
    St. John's
    Thanks all Beavis was right. It was just the dust cover. I bent it away and the squeeking and scraping stopped. I got to check the wheel bearings and brakes though and all was good,, Thanks for the help and suggestions.:)
