Front rotor problems?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, May 23, 2018.
  1. May 23, 2018 at 12:07 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    what can cause this and how to fix? When i step on my brake any speed it make a stutter stop. I dont slam on the brake just regular braking. Is the rotor warped? what should i do? i just changed the pads 5k ago. is there anything else wrong?
  2. May 23, 2018 at 12:14 PM
    BEE-ROCK
    BEE-ROCK Well-Known Member
    Brock
    Dallas, TX
    2013 Tacoma TRD Sport
    TRD Pro Grille, TRD Pro Headlights, Bilstein 5100's and 5125’s.
    Sounds like your rotors are warped.
    Alexely999, 270Fan, Grey 2015 and 3 others like this.
  3. May 23, 2018 at 12:26 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Replace the rotors or have them machined.
    Alexely999 likes this.
  4. May 23, 2018 at 12:27 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    just replace, rotors and pads...Its just easier...
    Alexely999 and Bebop[QUOTED] like this.
  5. May 23, 2018 at 12:30 PM
    Bebop
    Nick
    I have a lathe. Cheaper to machine them for me.
    BEE-ROCK likes this.
  6. May 23, 2018 at 1:08 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    try several hard stops and see if it goes away
    I always replace pads and rotors (machine if in spec) as a set
  7. May 23, 2018 at 1:18 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Check the torque on your lug nuts. Overtightening them can warp the rotor giving you a shudder especially on hard stops. Loosen and re-torque to spec. About 85 ft-lbs. Happened to me after tire shop installed new tires for me. Drove around for 1500 miles before I found out about the effect of lug nut torque. Thought the tires were causing the shudder or that my tie rods were going bad. Loosened and re-torqued to spec and it's been fine ever since. If it's not the lugs then no harm done. Free, quick and easy first check.
  8. May 24, 2018 at 12:26 PM
    pinktaco808
    Ook
    wilcam47 likes this.
  9. May 24, 2018 at 6:27 PM
    joemyself
    joemyself Well-Known Member
    As others have stated, your rotors are warped. I've had mine machine before and it lasted another 20k miles before I had to replace them completely. Not the end of the world if you have to replace them. Easy to do yourself if your good with a wrench.
    pinktaco808[OP] likes this.
  10. Jun 1, 2018 at 11:18 AM
    pinktaco808
    rears though
  11. Jun 1, 2018 at 11:24 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    That can also be a sign of a bad wheel bearing, when the brake pad hits the rotor it shifts over due to the slop in the bearing...ask me how I know
  12. Jun 1, 2018 at 11:48 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Your rotors aren’t warped. It takes a tremendous amount of heat to warp metal that thick.
    What happens when you brake aggressively or don’t seat new brakes properly you get an uneven brake pad wear on the rotor which causes uneven friction when breaking and hence shaking.
    I bet you didn’t seat the new brakes properly and you now need to turn the rotors to file off that uneven burned on brake pad material.
    If you are doing the work yourself it is cheaper to just replace the rotors then seat the brakes properly.
  13. Jun 1, 2018 at 12:11 PM
    Avsfreak18
    Avsfreak18 Now 5% less disappointing
    Robert
    2015 AC
    A repair shop over torqued the hell out of my wheels and warped a rotor a couple years ago... Problem went away the day I ended up replacing the rotors
  14. Jun 1, 2018 at 12:27 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I have never had much luck having warped rotors turned. I just replace them for as cheap as they are.
    wilcam47, kimo and Bebop[QUOTED] like this.
  15. Jun 1, 2018 at 4:33 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    If you replace your rotors, remember that there are several different quality levels of replacement rotors available out there. The cheapest ones - sometimes called "Chinese white box rotors" - won't last nearly as long as a better set of rotors. As with many other things, you get what you pay for.
    07 sport 4x4 likes this.
  16. Jun 2, 2018 at 6:41 AM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I bought a set from Napa(white box)they lasted about a week.
  17. Jun 2, 2018 at 6:52 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
  18. Jun 2, 2018 at 1:05 PM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    What he said ^^^ The straight dope on 'warped' rotors... http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
    And, while drilled and slotted rotors may look cool, they have absolutely zero benefit for vehicles that get used the way ours typically do. Buy high quality OEM type replacement rotors and pads, bed the new pads properly, and you'll be good to go.
  19. Jun 2, 2018 at 1:16 PM
    Aerose91
    Aerose91 Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    What do you guys mean by seat the pads properly
  20. Jun 2, 2018 at 1:27 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
