Front Rotor turn to fix vibration?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bishtacova, Dec 30, 2009.
  1. Dec 30, 2009 at 5:16 PM
    bishtacova
    bishtacova [OP] Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    Dudes,
    I have a mild vibration in my front end, took it to the dealer who turned and shaved the rotors. Issue is still there, specifically mild vibration to stop from 30mph or so, intermittently. Has anyone had this issue? What should I ask for next, new rotors? They didn't say the rotors were warped. Only 6600 mi on my taco.
    thanks!
  2. Dec 30, 2009 at 5:19 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    What about tire balance? Do you have any lift mods? Mine vibrated a lot until I swapped rotors. Went to PowerSlots. All gone.
  3. Dec 30, 2009 at 5:35 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    If they turned the rotors they should have changed the pads as well. Also, it could be a wheel out of balance or a tire out of round.
  4. Dec 30, 2009 at 5:58 PM
    russell@stone-creek.com
    russell@stone-creek.com Member
    If it vibrates when you are not on the brakes, rotors were never the problem.
    Intermittent vibrations are almost tire/balance issues.
  5. Dec 30, 2009 at 6:07 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    dude..........how does it vibrate?do you feel a pulsation in the brake pedal?do you feel it in the steering wheel?
  6. Dec 31, 2009 at 2:59 AM
    bishtacova
    I feel the vibration when I brake, mostly in the pedal and a little in the steering wheel. Should I ask for new rotors since they were turned?
  7. Dec 31, 2009 at 4:20 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I would ask for new rotors AND pads. You want two true surfaces working together. BTW, if they turned the rotors due to vibration, it's because they were warped;maybe defective from factory/poor quality.
  8. Jan 1, 2010 at 12:09 PM
    bishtacova
    I still have the shudder so the dealership is going to replace the rear drums. Has anyone had their rear brake drums replaced under warranty to fix mild shudder when braking around 40mph?
  9. Jan 1, 2010 at 3:47 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
  10. Jan 18, 2010 at 3:53 PM
    bishtacova
    My rear brake drums definitely cleared up the vibration I felt in the seat. But I have to go back and have them look at my front brakes they turned that didn't need them.
