Front Rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOMA TRD, Mar 29, 2011.
  1. Mar 29, 2011 at 2:21 PM
    TACOMA TRD
    TACOMA TRD [OP] Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Last year I replaced my front pads on my truck and used raybestos ceramic pad. When I did this the rotors were fine. This year when I hit the brakes I can feel a small shake in the wheel when I apply the brakes. Im assuming the rotors are now warped slightly. The truck has 50k and the rotors were not touched yet. Keep in mind I do live on a mountain area so 50k is great for rotors not being touched.
    Is it ok to have them turned, or should I just bite the bullet and replace them. If replaced should I use Toyota rotors? or are aftermarket ok.
    Thanks
  2. Mar 29, 2011 at 2:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Your choice. You should be able to have them turned.
  3. Mar 29, 2011 at 5:37 PM
    justindwhite
    justindwhite Member
    tulsa ok
    06 tacoma trd 4x4
    When you replace the pads or the rotors. The rotors should be turned and the pads should be new so they can break in together the brakes will last longer and stop better.
  4. Mar 29, 2011 at 5:38 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    using the ceramic brake pads may be wearing down your rotors.
    i would upgrade the rotors
  5. Mar 29, 2011 at 8:13 PM
    TACOMA TRD
    Tom
    PA
  6. Mar 29, 2011 at 9:24 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    2011 DC 4X4 TRD Sport
    RCD Lift, Custon Alcan Leafs, Ballistic Jesters, Duratracs 285/70/17,Fold-a-Cover Elite G4 Tonneau, Black Grill Emblem, Sock Monkey Yeti Decals, Tundra 4x4 emblem sprayed black, Debadged, LED interior, Xenon Depot 6000K HID Headlights, Xenon Depot 3000k Fogs with Lamin-X Coating, Borla Exhaust - Chopped, Weathertecs, Custom Katzkin Leather TRD Interior.
    Centric rotors
