Front rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stokka, Jun 16, 2017.
  1. Jun 16, 2017 at 3:36 PM
    stokka
    stokka [OP] Well-Known Member
    British Columbia
    2015 DCLB 4x4 SR5
    How many miles you are getting from your OEM front rotors befor replace?
    I have a huge pulsation while breaking and dealer says "warped, replace". 2015 DCLB with about 35 K miles. Is it reasonable?
    No heavy loads, no towing. Live close to mountains and often drive up and down, but use engine breaks a lot.
  2. Jun 16, 2017 at 3:43 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Really just depends on how the truck has been driven in terms of stopping. Constantly slamming on the breaks vs slow braking.
    stokka[OP] likes this.
  3. Jun 16, 2017 at 3:49 PM
    stokka
    British Columbia
    2015 DCLB 4x4 SR5
    50/50 city/highway driving. In a city I am not driving like constant PMS, but sometimes you do need to break. No way around it.
  4. Jun 16, 2017 at 3:50 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    70k for me, replaced with pads. Mostly city.
  5. Jun 16, 2017 at 3:52 PM
    stokka
    British Columbia
    2015 DCLB 4x4 SR5
    Do you have bed cap and/or any armor?
  6. Jun 16, 2017 at 3:54 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Got 150k on my OEM brakes.
    Shudder can be many things. Rotors don't usually warp.
    Clearwater Bill and stokka[OP] like this.
  7. Jun 16, 2017 at 3:54 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I replaced original front pads with OEM pads at 70K miles last year. Rotors were fine. If this second set of pads lasts another 70K miles, I'll replace rotors if needed. 60/40 (city/highway) driving with no hard breaking for the most part. No towing.
    Plain Jane Taco and stokka[OP] like this.
  8. Jun 16, 2017 at 4:17 PM
    ABA180
    East Bridgewater MA
    Nope. Just a light bar with PIAA lights and Nerf bars
    stokka[QUOTED][OP] likes this.
  9. Jun 16, 2017 at 5:49 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm at 180,000 miles and still on the original rotors. I've had the issue in the past and have had my rotors turned 3 times to correct the problem. Last time I didn't need new brakes. Having the rotors taken off, turned, and put back on was only slightly more expensive than a tire rotation. Less than the cost of just 1 rotor, not including labor. I'd look at that first.
    Of course if yours are warped too bad they may have to be replaced.
  10. Jun 16, 2017 at 10:13 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Have you had to make many panic stops in those 35k miles? Often what is perceived as a warped rotor simply has buildup up friction material in one or more spots.
    Think of this scenario: You're doing 70mph on the interstate and then something in the road requires you to slam on the brakes. You panic and stand on the brake pedal until you come to a stop, and because of the situation at the time, you KEEP the brake pedal pressed while stopped.
    So the massive heat buildup that occurred while you went from 70mph to 0mph is there, and then you have your brake pads sitting locked against the rotor in one spot for who knows how long. It only has to happen once for material to transfer to the rotor.
    Conveniently enough, the fix for this is to do the same thing, but instead of staying in one spot once stopped, you slow to like 10-15mph and then get back up to speed and repeat the hard stops until you have heat-cycled the rotors enough to cook off any material. The link below explains the process.
    https://www.zeckhausen.com/catalog/index.php?cPath=6446_6443
    Jimmyh and stokka[QUOTED][OP] like this.
  11. Jun 17, 2017 at 8:08 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I got 110,000 miles on my original pads and rotors in hilly western Pa. and was pleased. Never had that kind of performance from any other vehicle in 39 years of driving...
  12. Jun 17, 2017 at 8:14 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Got 80k from mine.
  13. Jun 17, 2017 at 8:18 AM
    Mavrick
    Mavrick Well-Known Member
    2015 DCSBOR
    Just replace my warped rotors on my 2015 at 47,000 miles, pads looked about half gone but replaced them as well. This fixed my pulse and everything is smooth again.
  14. Jun 17, 2017 at 8:37 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    They dont warp its pad material. You can get them resurfaced. You may be able to do it yourself.
    stokka[OP] and Clearwater Bill like this.
  15. Jun 17, 2017 at 8:41 AM
    Clearwater Bill
    Billy
    Largo Florida
  16. Jun 17, 2017 at 10:41 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Warranty does not cover it? Dealer replaced rotors and pads on wife's Lexus at 30K when she complained of shuddering when braking.
    My OEM rotors were fine when at about 70K I replaced them with EBC rotors. Kept the OEM rotors and at about 150K, I re-installed them, after resurfacing them, when the EBC rotors started to cause shuddering.
  17. Jun 17, 2017 at 10:46 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    My 2013 OEM rotors are at 77,000 miles now and I can tell they need to be resurfaced. I want to change them out but I am dealing with some health BS right now so it with every damn thing else is on the back burner right now.
  18. Jun 17, 2017 at 6:18 PM
    Mavrick
    2015 DCSBOR
    Yes they do, I used to turn them and you could clearly see the warp in it.
    stokka[OP] and vssman like this.
  19. Jun 17, 2017 at 8:56 PM
    taco2010trd
    Tampa, Florida
  20. Jun 18, 2017 at 6:05 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Replaced mine at 75k with brembo blanks and so far so good.
    taco2010trd likes this.
