front sag!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewsky, Sep 30, 2011.
  1. Sep 30, 2011 at 12:28 PM
    drewsky
    drewsky [OP] Active Member
    Drew
    Kelowna BC
    08 DOUBLE CAB 4X4
    Howdy! Seems my truck has 3" block lift in the rear, and 2"strut spacers on the front! Iput on my new winch and bumper, and seems like I'm gonna need to get higher up front? Need atleast 3-4" more, Any ideas????
    Cheers:confused:
  2. Sep 30, 2011 at 12:29 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    New front springs.
  3. Sep 30, 2011 at 12:30 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    My first idea would be to rip all of that junk out and do it right. Spacer lifts are not desirable and you won't find many people that are happy with them.
    Some answers to the following questions will help a ton...
    What do you use your truck for?
    What is your budget?
    What size tires are you running/do you want to run?
    Fink
  4. Sep 30, 2011 at 12:38 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you already have a 2" strut spacer and want to go up another 3-4", you need a drop bracket lift (like a Fabtech or ProComp 6" lift). You can't put a 6" suspension lift on the front of a Tacoma, you'll tear up your CV joints and wear through CV boots very quickly.
    Fink is right though, ditch the spacers and blocks, the ride will be much better and it will be much more functional.
  5. Sep 30, 2011 at 12:57 PM
    drewsky
    Drew
    Kelowna BC
    08 DOUBLE CAB 4X4
    I use my truck for the outdoors a lot, hunting,fishing, etc. I have 33" Duratracs on, and don't want to spend a ton, so I'm looking for different options??
  6. Sep 30, 2011 at 1:11 PM
    Pugga
    Massachusetts
    F-150 Mod
    I'd save your money and get a better suspension lift when you can. Dumping more money into trying to fix a cheap spacer lift isn't really money well spent.
  7. Sep 30, 2011 at 1:20 PM
    drewsky
    Drew
    Kelowna BC
    08 DOUBLE CAB 4X4
    What about new coils??
  8. Sep 30, 2011 at 1:23 PM
    Pugga
    Massachusetts
    F-150 Mod
    New lift coils would be a better solution than what you have now but you can't go up to 5" of lift in the front without further modification. 2.5" of lift is about all you can do without needing additional parts. Once you push 3" of lift up front you'll need new UCA's to get proper alignment and if you keep going you need to do something to drop the front differential otherwise your CV angles will be terrible.
    Something like the Old Man Emu struts and 886 coils would be good for your situation. They're much heavier coils so you can get around 3" of lift even with your heavy front bumper and winch.
  9. Sep 30, 2011 at 2:01 PM
    Fink
    Orlando, FL
    Fink
  10. Oct 3, 2011 at 6:17 PM
    drewsky
    Drew
    Kelowna BC
    08 DOUBLE CAB 4X4
    Just wondering again, would a 6" Fabtech dirt logic adjustable coil/strut be way too high for my issue??
  11. Oct 3, 2011 at 6:40 PM
    Fink
    Orlando, FL
    I guess I don't understand what the purpose of having such a tall truck is? I know you said you would your winch bumper on and you were going to need more lift...but compensating for the extra weigh, and lifting the truck six inches seem to be on opposite sides of the spectrum. :confused:
    Fink
  12. Oct 3, 2011 at 6:48 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    So you don't want to spend a lot of money?
    :confused::confused::confused:
    You're looking at over 3k with install.
    If you don't want to spend a lot of money, you need a new hobby
  13. Oct 3, 2011 at 6:53 PM
    Pugga
    Massachusetts
    F-150 Mod
    Dude, did you read my post? You can't just throw on a 6" lift coil without doing a bunch more work. You'd need the complete 6" drop bracket lift for that set-up otherwise you'll have serious issues with your CV joints and boots.
  14. Oct 3, 2011 at 6:59 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I'd just get some Bilstein 5100 shocks and Old Man Emu 886 springs for the front and a toytec 2" Add A Leaf for the rear and ditch that block...
    that'd handle your bumper up front just fine...might have to look into some new upper control arms for proper alignment purposes
  15. Oct 3, 2011 at 7:05 PM
    Pugga
    Massachusetts
    F-150 Mod
    I've heard nitrochargers are better paired with 886's than 5100's. I'm not sure how much truth their is to it, just what I've read on here but I agree that it'd be the way to go :thumbsup:
  16. Oct 3, 2011 at 7:09 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    You know what? Now that I think about it I think I heard that too. I got he 885s and i'm running a tubed bumper and I have no sagging at all. I'm about right at 3". The ride is awesome!
  17. Oct 5, 2011 at 5:11 AM
    Pugga
    Massachusetts
    F-150 Mod
    Sometimes I wish I had gone with OME rather than Eibach :pout: On the backroads the Eibachs are great, no truck roll, very stiff so cornering is nice but in the city, some softer coils would be nice (or maybe I need a plate bumper to settle them down a bit :D)
