Front Seat Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smtaco, Mar 6, 2017.
  1. Mar 6, 2017 at 9:58 AM
    smtaco
    smtaco [OP] New Member
    2017 TRD OR 4x4 DCSB
    Hi, i'm wondering if anyone has an issue with their front drivers seat. It feels like i'm sitting on a wire under the last row of stitching. Not sure if it's a wire, or stiff stitching that will give over time and loosen up. Passenger seat not as bad/stiff.
    TIA
  2. Mar 6, 2017 at 10:10 AM
    imjdoggie
    imjdoggie Well-Known Member
    J
    1995 Reg Cab 4x4
    Never felt anything like you are describing.
  3. Mar 6, 2017 at 10:16 AM
    su.b.rat
    su.b.rat broken truck
    :confused:
    no idea what yer talkin bout!
    but if you have some issue just with the seat design, and you simply don't like it, you can head to an upholstery shop and they can tweak the seat (foam, cover, etc). i did that because the seat was too high and too flat for me and was really uncomfortable. the fix is perfect. but i'm not sure about your issue, if you're saying you think something's wrong or if it's normal and you just don't like it.
  4. Mar 6, 2017 at 10:19 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    "et iunderhood" - FTW! :rofl::rofl::rofl:
    Just be glad your passenger seat doesn't look like there's a ghost inside...completely normal.
  5. Mar 6, 2017 at 12:52 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    talking about on the bottom portion? right before the side cushion part that curves up?
    I noticed the same thing.
    No clue what it is.
  6. Mar 6, 2017 at 1:38 PM
    TacoinMD
    TacoinMD Well-Known Member
    Tim
    Ft. Lauderdale, FL
    2017 Silver Double Cab Sport.
    I had the same issue on my driver's seat. I could feel a wire just under the stitching at the top left corner of the seat, kinda where the horizontal bolster meets the flat part of the seat where your ass sits. 2 different dealers looked at and said that is common, no need to worry.
  7. Mar 6, 2017 at 2:06 PM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Yeah, no need to worry about a wire poking in your ass.... completely normal.
    So get a two-fer... Howling Rear and wire in the ass... Turd Gen.
    or that would turn into a 3-fer:
    OP howling about a wire in his ass while the rear is howling. Problem solved.
    outlawtacoma likes this.
  8. Mar 6, 2017 at 2:08 PM
    jLEE028
    jLEE028 Well-Known Member
    MKE
    heated seats?
  9. Mar 6, 2017 at 2:12 PM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    4-fer... OP Howling about a wire in his ass + electrocuting him while his rear end is howling.... makes perfect sense.
  10. Mar 6, 2017 at 2:30 PM
    6172crew
    6172crew Well-Known Member
    New Mexico
    4X4 TRD sport
    The seats do use wire to hold the seat covers down and into the shape they are. I bought some orange stitched covers and the wire is on the underneath side but only the foam holds them from not poking you in the arse. The wire is 2-3 times as thick as a wire coat hanger.
  11. Mar 6, 2017 at 7:19 PM
    vimal
    vimal Member
    Vimal
    2016 Tavoma
    Hello. My 2016 Tacoma SR5 had the same issue. The spring was almost poking thru the seats. Tried getting a new seat from Toyota but no luck. They send me to a local upholstery place to get it fixed. Got a rental though.
