Front Seat Removal
Discussion in 'Technical Chat' started by rb11701, Mar 27, 2011.
  1. Mar 27, 2011 at 10:11 AM
    rb11701
    rb11701 [OP] Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I want to pull my seats out to install my seat covers, clean the carpet and re-route some stereo wires. I have airbags in the seats. What would be the procedure for this and not screw anything up with the airbag?
    I was thinking that if the battery is disconnect for 1/2 hour or so I should be fine to disconnect the seat. Does this sound safe? Now, is there only one plug that I have to worry about or is the airbag plug different.
    Also, anyone know the size of the bolt and the tourqe if needed?
    Thanks!
  2. Mar 27, 2011 at 10:14 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    14mm.....disconnecting the battery isnt necessary i wouldnt think
  3. Mar 27, 2011 at 10:18 AM
    rb11701
    Rob
    Thanks! At first I was thinking that but I am afraid I will trip the system if I pull it off when power is still there. Don't want to throw a warning light or worse yet deploy the side airbag lol. Man that would suck.
  4. Mar 27, 2011 at 11:06 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The FSM prescribes turning the ignition to the 'Lock' position (full 'off'), disconnecting the negative terminal of the battery, and waiting at least 90 seconds.
  5. Mar 27, 2011 at 11:12 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    i took mine off with the key in the on position yesterday...all it did was indicate that the passenger side airbag was off and drivers side dash light came on...then put them back in and all i did was turn the truck back on and it was fine :cool:
