Front Seat Squeak
Discussion in '1st Gen. Tacomas (1995-2004)' started by bpiersma, Feb 10, 2009.
  1. Feb 10, 2009 at 10:22 PM
    bpiersma
    bpiersma [OP] Member
    Solvang, CA
    2001 PreRunner TRD Lunar Mist
    I recently noticed that my front driver's seat has a "squeaking" sound when I put pressure on it. If I push right against where your back goes, I get this squeak or grinding type of sound. Like there are two sheets of rubber rubbing against one another on the inside of the cushion. Doesn't happen on the passenger seat.
    Anyone have this? I also noticed that the door panel does the same, but again, just the driver's side.
    It's irritating!
  2. Feb 11, 2009 at 4:50 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    yeah i have sqeaks in both front seats and it drives me nuts too. wish i could tell you what it was. ive taken the seats out and tightened all the bolts but didnt help the sqeak.
  3. Feb 11, 2009 at 4:51 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Loose the seats and bolt in a wooden bench. Thats what i did! lol
  4. Feb 11, 2009 at 4:54 PM
    hulzenga
    hulzenga Member
    Kelowna Bc
    1999 toyota tacoma 4X4
    2" blocks, ya i know, not enough....
    I got me the same issue! But my drivers seat sqeaks, and my passenger door squeaks when you open it up to the max. really annoying, probably going to have a closer look at the two of them this weekend....i'll let ya know what i find.
  5. Feb 11, 2009 at 7:42 PM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    same problem my drivers seat sqeaks pretty bad it gets on my nerves pretty bad....
  6. Feb 11, 2009 at 10:39 PM
    bpiersma
    Solvang, CA
    We gotta figure this out folks. There must be a fix. I think I'll pull my seat out this weekend and see if I can get inside the cushion to see what's squeaking. It drives me crazy.
  7. Feb 11, 2009 at 10:44 PM
    hulzenga
    hulzenga Member
    Kelowna Bc
    I'm game, but this weekend i'm going flyfishing with my dad, so its gonna have to be next weekend for me. I was wiggeling some stuff under there tonight, and notice one part (not sure) that seemed to be moving that shouldn't be, so thats where i'm going to start. It was under the front right corner....don't know if that helps you out at all. I'm gonna go nuts after this little squeak and get'er done!!
  8. Feb 12, 2009 at 3:43 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    i pulled the seat out a few months ago to install my amp wire and there is a peg type thing that holds the seat in place and it rubs metal to metal.....im thinkng about puttin some rubber around the peg to see if it stops
  9. Dec 21, 2010 at 4:50 PM
    yodaman
    yodaman Active Member
    Bellingham
    07 TRD Sport 4x4 V6 Automatic
    Yokohama tires Skyjacker canopy add more later
    You guys likely have this all figured out by now. There are two pegs located near the floor bolts on the front of the seats. Those pegs are what causes the squeak due to metal rubbing on metal. Take the seat out and cut the pegs off with a hacksaw or dremal (spelling?) tool. No more noise.
    Simple fix. Good luck.
  10. Feb 8, 2011 at 4:11 PM
    RomeGaTacoma4x4
    RomeGaTacoma4x4 New Member
    J
    Ga
    2010 Tacoma TRD 4x4, White
    Exactly, the pegs under the seat. I took my 2010 Tacoma In today bc the seat squeaking and they realized it was the pegs rubbing the metal. The dealer cut the pegs down and its perfect now. Tightening the bolts will not work it just prolongs the noise to get worse overtime.
  11. Feb 8, 2011 at 4:27 PM
    bromagen25
    bromagen25 Well-Known Member
    Stock
    Rear Breather
    had the same problem here's the Fix for me. hope it woks for you guys as well.
    Take the bolt out completely in the front. take wd 40 or grease and wipe it on the back side of the bolt head (( do not spray the wd 40 )) rub it on just a little bit not a lot same for the grease. then put the bolt back on and your good to go. Remember you only need a little.
  12. Dec 14, 2011 at 12:49 PM
    hialtitude
    hialtitude New Member
    Missoula, MT
    08 tacoma
    I have the same squeeking on the drivers side of my bench seat. I am having a hard time finding the peg that may be causing the noise. Is it visible before removing the seat? Any tips and/or tricks to make this as easy as possible? I would really like to avoid taking my truck in for this if its an easy fix. Thanks.
  13. Dec 14, 2011 at 1:04 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Is it a fart traped in the cushion lol.
  14. Dec 15, 2011 at 3:40 AM
    yodaman
    Bellingham
    They should be very easy too see. If I remember right, I unbolted my entire seat and leaned it back. From there I sawed off the pegs. I didn't even saw them flush, just enough to stop that freaking noise. I thought about greasing them but you might as well chop them off. PM me if you have any questions.
  15. Feb 19, 2014 at 4:40 AM
    surfryhder
    surfryhder Well-Known Member
    2013 TRD Offroad 4X4
    Anyone got any pics of how you fixed it?
  16. Feb 19, 2014 at 5:29 AM
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    PUT THE FORK DOWN!
    kiddin,,:eek:
