Front seatbelt slow to retract
Discussion in '1st Gen. Tacomas (1995-2004)' started by rickdiamond, Mar 1, 2020.
  1. Mar 1, 2020 at 9:23 PM
    rickdiamond
    rickdiamond [OP] Waffle House and guns
    Ritchie
    Valdosta GA
    2017 Taco TRD Pro
    I have a doublecab Taco and the rear seatbelts retract just fine. However both the front seatbelts(passenger side is considerably slower) are slow to retract and quite often get stuck in the door jamb by myself or passengers when not paying attention or in a hurry to get out. Any advice on what could be done to speed them back up to factory? Thanks!
  2. Mar 2, 2020 at 3:01 AM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    I think this is a pretty well-known issue. Mine do it, I've just been living with it. But I'm sure there are plenty of threads on it
    rickdiamond[OP] likes this.
  3. Mar 2, 2020 at 3:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Silicone spray from use the seat belts get dirty my right seat belt never getting used is like new.
  4. Mar 2, 2020 at 3:45 AM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    YouTube has a bunch of videos. The belt is dirty. It gets slightly thicker and stiffer because of this and causes it to retract poorly. Mainly you clean the belt and the problem is solved but it takes soaking it in a soapy bucket so it's a bit of a pain
    joe25rs and rickdiamond[OP] like this.
  5. Mar 2, 2020 at 5:09 AM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    i soak my inside a bucket with soap n water Scrub then . W40 the hell out the mechanical gears an now they work like new . Save me lots of $$$ .
  6. Mar 2, 2020 at 6:01 AM
    Indy
    Indy Master of all I survey.
    Clean it and lube it.
  7. Mar 2, 2020 at 6:03 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i assume you have to fully remove the whole thing from the rig to do this :notsure:
    my belt has been a very limpy richard and its been like this since most likely the mid 2000s or earlier, i forget when it started limping anymore
    @jammer what do you think about this method?
    i think my belts are 'clean' but may likely be microscopically 'dirty'
    maybe use Nut-Z lube instead of WD40 on mechanical gears for longer lasting lube?
  8. Mar 2, 2020 at 6:10 AM
    Indy
    It's not generally the belts, it's the mech.
    ericvega, GQ7227 and rickdiamond[OP] like this.
  9. Mar 2, 2020 at 6:49 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Good luck with your cleaning, let us know how it turns out!
  10. Mar 2, 2020 at 6:50 AM
    phx70
    phx70 Well-Known Member
    Joe
    Scottsdale Arizona
    1999 Tacoma SR5 4WD 3RZ AT Sunfire Red Pearl
    Does the belt seem to get stuck/folded in the shoulder guide?
  11. Mar 2, 2020 at 6:51 AM
    rickdiamond
    Ritchie
    Valdosta GA
    2017 Taco TRD Pro
    Will do, I’ll probably get on it today or tomorrow. I’ll take pics throughout!
  12. Mar 2, 2020 at 5:50 PM
    rickdiamond
    Ritchie
    Valdosta GA
    2017 Taco TRD Pro
    Not really, it’s just super super slow to retract so I have to give it a few pulls on the way back in.
    six5crèéd likes this.
  13. Mar 2, 2020 at 6:43 PM
    gsrogers
    gsrogers 2003 TRD 4X4
    Garry
    Friendswood Texas
    2003 Tacoma DC TRD 4X4
    Fabtech 6" with Alcan 6" rear springs 33" Nitto Terra Grapplers
    Mine did the same thing.....not sure if it was dirt but mine seemed like the belt fabric got "stiff". I bit the bullet and bought 2 new front assemblies. That fixed it for good.
  14. Mar 3, 2020 at 6:43 AM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    I’ve tried a few different fixes for this. First is Velcro on the side of your seats, as well as the lower part of the seatbelt.
    I haven’t tried this yet, but I had an idea of using a piece of elastic attached to both the belt and the side of the seat with a bolt/tied somewhere, and when you let go of your seatbelt, the elastic will bring it so that it doesn’t fall into the door, but when you want to put your seatbelt back on, the elastic allows for it to be pulled so that you can do so.
    the Velcro doesn’t work very well but I see other people do it well. The issue I experienced with the Velcro was the stickyness of it (need a hairdryer or a heat gun to heat it before applying) and how it doesn’t give much wiggle room. I actually ended up pulling the Velcro off both sides of my Tacoma because I didn’t take into consideration how you can adjust the angle of your seats as well as how far up they are.
    In my opinion I feel although the elastic is a good option, and I’m going to make a write up explaining how to do this once I get back home from being in Latin America. Should have the post up in around 4 months or so.
    goodluck :)
  15. Mar 3, 2020 at 7:04 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    maybe i will try cleaning the shoulder guide with qTip and see if it helps!
    just use some stoner glass cleaner or something stronger?
  16. Mar 3, 2020 at 7:05 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I just sprayed my belt and the guide up top with silicone spray, will report back with if it helps or not.
    GQ7227 likes this.
  17. Mar 3, 2020 at 7:51 AM
    gsrogers
    Garry
    Friendswood Texas
    rickdiamond[OP], GQ7227 and jammer like this.
  18. Mar 3, 2020 at 7:53 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Yes, totally agree! Trust me.......from experience.
    I just replaced my drivers side with a new seat belt assembly from Camelback Toyota Parts and it's tight as a drum now!
    rickdiamond[OP] and GQ7227 like this.
  19. Mar 3, 2020 at 7:55 AM
    jammer
    Ben
    Bentonville, AR
    My experience.
    https://www.tacomaworld.com/threads/seat-belt-pretensioner-repair-final-update-must-read.650694/
    GQ7227 likes this.
  20. Mar 3, 2020 at 7:55 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the 'expensive' part i am seeing is the installation of the new part :bananadead:
    had a pro quote once but have forgotten what it was ex-part
    my frustrations of limp belt have been going on for probably 15 years now since i started wearing it most all of the time
