Front Shock-Coil Over Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RunningFred, Jul 11, 2024.
  1. Jul 11, 2024 at 11:54 AM
    RunningFred
    RunningFred [OP] Member
    2005 PreRunner 2wd/2018 TRD
    None
    Gen 3, TRD Off Road with 90K miles. Over the road driver, no off road or heavy hauling.
    Question: Replacing the front shocks with Bilstein 4600's. Is there any need to replace the coil over spring? Not looking for a lift. How long do these springs last? Thanks
  2. Jul 11, 2024 at 11:55 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    They should last the life of the truck.
    RunningFred[OP] likes this.
  3. Jul 11, 2024 at 11:56 AM
    RunningFred
    None
    I have another Tacoma- 2005 with 350K miles. I'm replacing the front shocks on that as well. How about that coil spring?
  4. Jul 11, 2024 at 12:00 PM
    gudujarlson
    Minnesota
    Assuming it’s not excessively rusted or cracked and there are no suspension modifications or added weight, you can measure your ride height and compare it to stock. If the spring rate or length of the spring has changed, the ride height will be lower than stock. Alternatively, you could remove the spring and measure it’s spring rate and length and compare it to a new spring.
  5. Jul 11, 2024 at 12:01 PM
    RunningFred
    None
    Thanks. Might just pick up the package shock/spring. She deserves it.
  6. Jul 11, 2024 at 12:03 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    If the springs aren't noticeably sagging and not rusted or damaged, you should be able to keep them.
  7. Jul 11, 2024 at 12:04 PM
    gudujarlson
    Minnesota
    Another reason to replace the whole coilover is that it’s an easier to install because you don’t need to disassemble and reassemble the coil over.
    But otherwise I personally would never replace a spring that didn’t fail a proper inspection. I think people often replace perfectly good springs because they look old.
