Front Shock Issue...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nicktoria, Apr 1, 2012.
  1. Apr 1, 2012 at 7:17 PM
    nicktoria
    nicktoria [OP] Member
    Nick
    Iqaluit
    Hey there,
    New to the Tacoma world, chiming in from Iqaluit Nunavut.
    Have a 2007 Tacoma TRD, with a 2.5" lift & 33's.
    Recently had new Bilstein 5100 series shocks installed on the front and rear end and there seems to be a problem.
    It appears there is a gap between the top of the strut mount plate and bolt at the top of the shock itself.
    On the drivers side it appears it is on an angle vs the passenger.
    Attached pictures to help with the visualization!
    Is there a spacer involved?
    Please let me know what I can do to correct the problem!! Thank-you!!
  2. Apr 1, 2012 at 7:23 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Thats a 50$ spacer lift not 5100s, did you take it to a shop? I would raise hell if a shop installed that crap on my stock stuff when I paid for 5100s.
  3. Apr 1, 2012 at 7:25 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yeah, doesn't look like 5100s to me. Does look like they broke the assembly though. Like the shaft is bent.
  4. Apr 1, 2012 at 7:30 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    i am so happy i know how to turn a wrench....
  5. Apr 1, 2012 at 7:35 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    need more pics but your one shock is broken or missing the washers and bushing.
    and if those are 5100s there shouldnt be a spacer there
  6. Apr 1, 2012 at 7:39 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Wow. What shop did that?! That's a pitiful excuse for a lift.
  7. Apr 1, 2012 at 7:49 PM
    Yoytoda
    Roland
    completely stock
  8. Apr 1, 2012 at 7:58 PM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    Looks like they forgot the top washer and bushing.
  9. Apr 1, 2012 at 7:59 PM
    Yoytoda
    Roland
    completely stock
    the bottom ones would be missing too if the shaft can go that far up
  10. Apr 1, 2012 at 8:04 PM
    Jones
    Texas DFW
    I was just thinking they same thing.
    OP- I would not drive with it that way.
  11. Apr 2, 2012 at 4:33 AM
    nicktoria
    Nick
    Iqaluit
    See here in Iqaluit, we only have so many mechanics we can go to. It really bothers me to know that we pay 150/hr for work to be done on our vehicles when it's not even done right! I have a 2006 Jeep Rubicon LongArm Kit the whole works - I can't drive it because the mechanics screw the T/C from a misaligned drive shaft.
    So from this point it appears the lift is not a good one; can someone tell me what I need in order to have a proper lift? Also, the 5100's are appearently adjustible up to 2.5", could this be the issue as well?
    I am new to the Tacoma's and the lift was already on before I got it. So I need information!! I also had a new wheel hub assembly, CV BOOT, and strut mount put on the drivers side last month! Then I noticed a squeek!
    Help! I'll try to get more pictures!
  12. Apr 2, 2012 at 5:07 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    How does that not look like a 5100??? What is it about the black boot in the pic that looks so much different than the black boot on a 5100 that has people saying those aren't 5100s?
  13. Apr 2, 2012 at 5:17 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Looks that way to me as well, the black boot suggests 5100's are installed-
    but 5100's are not designed to be run with spacers, #1 problem. :eek:
  14. Apr 2, 2012 at 5:18 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    the angle looks like it's from the coil being upside down.
  15. Apr 2, 2012 at 5:19 AM
    Bryan139
    NJ
    '09 Sport
    It looks like you're missing a bushing. There's something missing, that's pretty much a given. It's not a big deal, but you're going to have to get in there and open it up and see which part is missing. Guys have had this problem when they try to leave the black boot off. They end up leaving the metal bushing out that's built into the boot. Just like you're going to have to do, they end up taking the whole thing back apart and putting in that bushing. Weather you have it done or do it yourself, that's pretty much what needs to happen. You can find step by step how-to instructions with pics all over TW. It's not that hard. I did it, and I don't know shit about trucks. I didn't even know I had air bags but I did my own 5100s, so I'm betting you can too.
  16. Apr 2, 2012 at 5:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    Top plates are installed in the wrong spot. The aluminum piece is supposed to go on top of the top plate. That must have been a bitch to compress. Chances are you just wore a nice hole through that top plate.
    EDIT: ok maybe they are in the right spot but it looks like you're missing the top plate on the first pic.
  17. Apr 2, 2012 at 5:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    Agreed.
