Front Shock Support Assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08TacoTrD, May 6, 2013.
  1. May 6, 2013 at 3:39 PM
    08TacoTrD
    08TacoTrD [OP] Well-Known Member
    08 TRD Offroad
    I noticed the other day that the rubber in the support assembly on the passenger side is being pushed out a little. I know there was a thread about this not too long ago but I can't find it. I am looking to find out if I can loosen the bolts and readjust it? Or not worry about since I am looking at a new suspension all around anyway but I am not close to pulling the trigger yet.
    Here is the passenger side
    Here is the driver side
  2. May 6, 2013 at 3:54 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The three bolts hold the top hat against the frame bucket. The rubber pad is between the top hat and spring coil. To adjust the pad, you'd have to get a spring compressor and squeeze the coil, to remove the pressure on the top hat.
  3. May 6, 2013 at 4:00 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I wouldn't worry about it. Especially of your upgrading soon.
  4. May 6, 2013 at 4:59 PM
    08TacoTrD
    08 TRD Offroad
    Thanks, I wasn't sure exactly where it was.
