Front shock top nut help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JReaperz, Jun 24, 2017.
  1. Jun 24, 2017 at 10:45 AM
    JReaperz
    JReaperz [OP] Well-Known Member
    JR
    Indiana
    2012 NatBlue DCLB SR5
    So im trying to replace my front original shocks and the top nut is rusted all to shit. I've hit it with pb blaster and a torch (lightly) but I cannot bust it loose. The main problem is that the shock keeps spinning and I've stripped the top stem where a wrench would hold it. Any ideas how I can keep the shock from spinning now that I cannot wrench the top stem?
  2. Jun 24, 2017 at 11:00 AM
    Nate-O
    Nate-O Well-Known Member
    Nate
    PreRunner
    Maybe try some vise grips or locking pliers to keep the shock from spinning. :notsure:
  3. Jun 24, 2017 at 11:02 AM
    JReaperz
    JR
    Indiana
    Thats what im trying now but so far no luck.
  4. Jun 24, 2017 at 11:05 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Dont know if there is a boot on your current shocks but if you're tossing them maybe try to lock vice grips on the shaft between the coil spring?
    An impact gun helps a lot too.
  5. Jun 24, 2017 at 11:07 AM
    JReaperz
    JR
    Indiana
    I will try the vice grips on the shaft idea.
  6. Jun 24, 2017 at 11:09 AM
    devkurf
    devkurf Member at Large
    midwest
    Sawzall at bottom of nut and be done with it. Thats what I did.
  7. Jun 24, 2017 at 11:10 AM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Or a cutting wheel on a grinder. Just make sure the spring is properly compressed and secure.
  8. Jun 24, 2017 at 11:11 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I had to use a cutting wheel on one of my rears. A sawzall works too
  9. Jun 24, 2017 at 11:12 AM
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Yup, just cut it off. Dremel and a cutting blade also works, thats what I had to do.
    Your old shocks are garbage anyway.
  10. Jun 24, 2017 at 11:13 AM
    JReaperz
    JR
    Indiana
    Alright im getting the sawzall out!
  11. Jun 24, 2017 at 11:19 AM
    devkurf
    midwest
    How are you compressing the spring? If you are using the jack method, just go really SLOW when you let it down, and try to keep body parts out of the way just in case.
  12. Jun 24, 2017 at 11:21 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Also, youre gonna find out if your alignment cams are seized. If youre lucky and theyre not, grease them up to keep them that way.
  13. Jun 24, 2017 at 11:26 AM
    JReaperz
    JR
    Indiana
    Cams are greased. I have a slow lowering jack. And a sawzall worked. Thanks everyone!!
