Front shocks 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lommadogg, Aug 11, 2023.
  1. Aug 11, 2023 at 7:28 PM
    Lommadogg
    Lommadogg [OP] Member
    2013 Tacoma Double Cab
    Can I simply replace the front shock on my 2013 and not the whole strut?
  2. Aug 11, 2023 at 7:57 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yes, technically, it is a coilover. You can just replace the shock and reuse the coil. If you are going to do this then call ahead to the shop since this isn’t efficient for a shop and they may charge extra. Coilovers don’t usually come assembled like a strut anyway.
    XSplicer62 likes this.
  3. Aug 11, 2023 at 8:16 PM
    davep2012
    davep2012 Well-Known Member
    Dave
    2012 Silver Tacoma
    Weather Tech floor mats and Marathon Seat Covers
    If you are a DIY'er, I highly recommend taking the assembly to a place that has a professional coil spring compressor and just pay them to swap the new shock in. Life is too short to deal with the Chinese spring compressors that are out there. I had one break and shoot a coil spring across the yard.
  4. Aug 11, 2023 at 8:37 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    As noted above, yes. Also as noted above, it is a coilover, not a strut. I recently replaced my rear shocks and had a shop replace my front shocks.
    Could have done the fronts myself but the older I get, the more I prefer to have a shop do some of the jobs that are a bit more involved.
  5. Aug 11, 2023 at 9:47 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    You CAN replace the shock absorber yourself, but not recommended. The spring tension on the coil over is substantial.
    If you want to do it yourself, please be very careful.
    You MUST get or rent two spring compressors to disassemble and reassemble the the coil from the shock absorber.
    If you are not careful the spring will jump at you and has enough energy to seriously injure.
    There is loads of videos, and literature on disassembly of the coilover from the truck, and coil to shocks absorber.
  6. Aug 12, 2023 at 6:02 AM
    davep2012
    Dave
    2012 Silver Tacoma
    To Mikes point, it is time consuming/frustrating trying to get the coil spring compressors in the exact spots to compressor the spring evenly going down and not putting the top part of the strut in a bind. I can tell you from experience that this was the worst part of the strut changing job. Bolting the assembly in and out is a piece of cake.
    Mike - nice '71/72 truck in your pic. I remember when those trucks were everywhere!
    XSplicer62[QUOTED] likes this.
  7. Aug 12, 2023 at 8:08 AM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Absolutely you can replace the spring only, but if you have more than 30k on the shocks, you might as well change them while you're in there. The front springs store a LOT of energy when compressed. If you do it yourself, wear safety goggles and treat the compressed spring like a bomb. Store them in a safe place (wooden box) while you do the rest of the work. I had to compress mine twice in the same week when I installed 5100s and didn't like them set to 2" lift . (Went with 3/4"). The dia. of the spring is quite large, so if you do it yourself, buy the best compressors you can. I like to do my own work, and have used my compressors on about 5 cars in the past 30 years. Take your time, use anti seize or loctite where recommended, and have fun!
