Front shocks?!!! (HELP!!)
Discussion in '1st Gen. Tacomas (1995-2004)' started by hillinsan, Dec 10, 2011.
  1. Dec 10, 2011 at 9:55 PM
    hillinsan
    hillinsan [OP] Active Member
    Beavercreek,OR
    tacoma 4wd TRD
    So I just bought my first Tacoma, its a 2001 4x4 trd. My front shocks are bad and I bought Bilstein 5100's and when I went to replace them, the first shock I went to remove gave me trouble so Im stuck until I get parts. The 3 bolts on the strut mount on top are rusted badly and the 3rd that I was working on loosened for about 5 turns and then the bolt turned with the nut and is stuck like that. Where can I get the replacement peice with the bult "lugs" so I can continure with the upgrade. Not really sure if its a strut mount or what you call it. Any help is very much appreciated.. Thanks Kenny
  2. Dec 10, 2011 at 10:00 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    I used grade 8 bolts and they work very well....just cut them off and do that or you will have to buy that whole top plate assm.
  3. Dec 10, 2011 at 10:00 PM
    sir1123
    Charleston
    i meant cut off that one and take out the others
  4. Dec 10, 2011 at 10:02 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    pics will help us!! a grinder is your friend sometimes, so is a torch, and... crap i forgot what that stuff is called that you spray on and it eats all the rust away and helps you get the nuts off.. hopefully someone else can chime in
  5. Dec 10, 2011 at 10:09 PM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    Where would I get the whole top plate assm.? Would I have to go through Toyota for that or can I find an after market one?
  6. Dec 10, 2011 at 10:10 PM
    97yota4wd
    Eric
    Mesa, AZ
    doesnt the 5100s come with it??
  7. Dec 10, 2011 at 10:12 PM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    there is a plate on the bottom, but on top theres just the rod and a nut. Not the top plate with bolts.
  8. Dec 10, 2011 at 10:15 PM
    97yota4wd
    Eric
    Mesa, AZ
    can you post some pics please?
    im tired and sick so maybe my brain isnt working lol
  9. Dec 10, 2011 at 10:24 PM
    sir1123
    Charleston
    no the 5100s dont have the top plate unless you get the coil over package. no i do not belive you can find it somewhere else other than toyota. this happenend to me and thats why i just used some grade 8 bolts...works perfect
  10. Dec 10, 2011 at 10:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Try here. I think they call it Strut Top Plate/Upper Coil Support
    http://www.wheelersoffroad.com/9504tacomasuspmisc.htm
  11. Dec 10, 2011 at 10:32 PM
    sir1123
    Charleston
  12. Dec 10, 2011 at 10:56 PM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    Thanks for the help guys!!
  13. Dec 11, 2011 at 8:43 AM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
  14. Dec 11, 2011 at 8:48 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    PB Blaster. Depending on how bad the rust is, though, cutting and replacing may be the better option.
  15. Dec 11, 2011 at 8:57 AM
    trdracing5
    Elizabeth City, NC
    1995 Tacoma 4X4
    Its always good to have a can of PB Blaster around!
