Front shocks?
Discussion in '1st Gen. Tacomas (1995-2004)' started by hillinsan, Nov 26, 2011.
  1. Nov 26, 2011 at 2:26 PM
    hillinsan
    hillinsan [OP] Active Member
    Beavercreek,OR
    tacoma 4wd TRD
    Just bought my first tacoma, I know the front shocks are bad so what im trying to figure out is what front shocks to buy that will work with a 2.5 or 3 inch lift. The driver side looks the worst the top of the shock above the revtek lift seems to be off center to the spring and the front end bounces up and down alot. Is it just a rubber spacer that would cause it to be off center? Any help would be appreciated. Thanx..
  2. Nov 26, 2011 at 2:42 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Welcome to TW!
    The forum's search function will help you find answers to many of your questions, most likely in the Suspension and 1st Gen Forums. FWIW, Bilstein and OME shocks are very popular, and both will work with 2"-3" lifts.
    Don't forget to consult the experts at and/or DownSouth Motorsports before you buy - both offer competitive pricing, great customer service, and TW member discounts.
  3. Nov 26, 2011 at 11:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    On a truck with a revtek spacer left, the shock is still basicaqlly a stock length shock. So if you have to replace it there are a few options open to you.
    You will find that the majority of experienced users will suggest removing the revtek spacer in favor of a repalcement shock from Bilstein that can provide up to 2.5" of lift. Check out Downsouth Motorsprt for RCD Billistein 5100s.
    http://downsouthmotorsports.com/i-1...pre-runner-4wd-front-pre-load-adjustable.html
  4. Nov 26, 2011 at 11:37 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    you can always get rid of the spacer and run bilstein 5100's on 2.5'' if you are low on cash. But the best option is to buy OME or Bilstein shocks and run a lift coil.
    Good luck
  5. Nov 27, 2011 at 1:35 PM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    how do i tell what lift is on the rear if at all. seems a bit higher in the rear than the pic ubove on digiratus's pic? i want to make sure the bilstein 5100 is going to be acceptable highth with the rear of my truck.
  6. Nov 27, 2011 at 3:56 PM
    TacoMX
    Jonathan
    Deltona, Florida
    take a picture of the rear end and the leaf springs from multiple angles and we can tell you.
    It could be blocks, AAL, or a shackle.
  7. Nov 27, 2011 at 4:31 PM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    Ok so I went to a local guy here and he looked at my truck. so whom ever had it before put a 2.5 inch lift in the rear with blocks and a revtek spacer kit on the front. The front shocks are shot and the driver side gromet it worn bad. Gonna get the bilstein 5100 adjustable preload to 2.5 and have my buddy help me. Any input would be helpful. is it a pain in the butt or is my buddy right,kinda simple and easy? I was worried about the spring giving me problems when putting the 5100's in. do i need to compress the spring with a tool or what? lol im such a newb at all this but im determined to get er done this next weekend.
  8. Nov 27, 2011 at 4:33 PM
    TacoMX
    Jonathan
    Deltona, Florida
    Its not hard. You will need to get spring compressors from autozone or advanced auto (rent). If its your first time, it will be frustrating, but not too hard of a job.
    For the rear I would take out that terrible block and do an AAL from Toytec.
    Goodluck
  9. Nov 27, 2011 at 5:21 PM
    hillinsan
    Beavercreek,OR
    tacoma 4wd TRD
    Thanks everyone for your help!!!! You guys rock!!!!! Ordered the bilstein 5100's on toytec and bushing and washer kit with the black friday coupon code and im under $230.00. this will save me alot for now, next will be the aal on the rear and get rid of those nasty blocks :)
  10. Nov 27, 2011 at 6:17 PM
    TacoMX
    Jonathan
    Deltona, Florida
    sounds good! get pics for us when you put them on. You will be very happy with the bilsteins and the AAL then the spacers/blocks.
    In the near future you should add Eibach coils to your bilsteins in the front for 3'' and a new leaf pack to level it out.
  11. Nov 27, 2011 at 9:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Review this thread for tips on the 5100s install.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/114418-bilstein-5100-install-thread.html
