Front shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomr67, Sep 13, 2023.
  1. Sep 13, 2023 at 12:38 PM
    tomr67
    tomr67 [OP] Member
    tom
    2013 tacoma
    5100 front new
    I have a 2013 tacoma 4x4. I recently replaced my front shocks with bilstens 5100. I set drivers side to one notch above stock and the other side I set it stock. I also replaced sway bar bushings and sway bar end links. I am getting noises when I go over small cracks in the road. Any ideas? I think is could be the different shock settings. But over all the ride great.
  2. Sep 13, 2023 at 1:00 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Look to verify the state of your control arm bushings and also check for play in your steering rack.
    Other sources of noise could be upper/lower ball joints
  3. Sep 13, 2023 at 1:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check the sway bar links too.
    I’ve seen worn and/or loose links cause noises like you described.
    Geeves77 and memario1214 like this.
