Front Spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cbell92129, Dec 27, 2016.
  1. Dec 27, 2016 at 7:35 AM
    cbell92129
    cbell92129 [OP] Active Member
    2012 Toyota Tacoma Pre Runner Texas Edition
    Bilstein 5100 all around, 34” Falken Wildpeak tires, Bed Cover, Flow Master exhaust, K&N filter, throttle body spacer, de-badged, rugged ridge fenders, Total Chaos upper and lower control arms, ICON coilovers
    Hi, new to the site, over the weekend I installed 1.5" front spacers on my '12 Taco to help clear my 33" tires, anyone else running this set up? I'm a little concerned on the threading. I was able to torque the spacers down to the same spec as the lug nuts, but they only threaded about 3/4 on the bolt. Going to check them in a few days and add some lock tight.....ride feels great btw.
  2. Dec 27, 2016 at 7:48 AM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    I did them to last week also. The ones i got was hub centric (spelling that wrong i know) But I used lock tight to, Just be prepared for comments of people saying on how dumb you are and bluh bluh bluh. lol Most people on where dont like spacers.
  3. Dec 27, 2016 at 7:53 AM
    cbell92129
    Thanks, did you have the same concern on yours? Ride is way better and no more rubbing....
  4. Dec 27, 2016 at 8:05 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Did you guy drive 10mi and re-torque? All Pro`s say to , until they wont re-torque .
  5. Dec 27, 2016 at 8:06 AM
    beetlevegas
    JP
    Las Vegas NV
    stuff
    No. it was fine when i torqued it down. No issues.
  6. Dec 27, 2016 at 8:12 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Those instructions have had me hesitant to put mine on. Was worried about loosening . Wife and kids are in it during the week, due to gas mileage for my job.
  7. Dec 27, 2016 at 8:13 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Beet , did you use red or blue loc-tite?
  8. Dec 27, 2016 at 8:15 AM
    cbell92129
    I just did them yesterday, going to re-torque and check in a few days. I did the blue loc-tite.
    REDdawn6 likes this.
  9. Dec 27, 2016 at 8:18 AM
    cbell92129
    I also figured 1.5" is better than 2", but I did find 1" or 1.25" in case I end up returning. Since they're seated I wonder what the true difference is in depth on the bolts between 1.5" and 1.25"...definitely not .25"...
  10. Dec 27, 2016 at 8:23 AM
    beetlevegas
    JP
    Las Vegas NV
    stuff
    I used blue and i did 1.25
  11. Dec 27, 2016 at 8:23 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Thanks man.
  12. Dec 27, 2016 at 8:26 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    My SpiderTrax spacers threaded on the stock lugs all the way. The studs protrude from the spacer lugs just a little bit. FWIW, I used red loctite...retorqued them after 100mi and now I retorque them whenever the wheels come off. Haven't had any issues and I've had them for probably 30k miles or more.
    cbell92129[OP] and REDdawn6 like this.
  13. Dec 27, 2016 at 8:30 AM
    cbell92129
    Thank You, here are a few pics, granted this is before I torqued them down, still only covered about 3/4 of the lug bolts....
  14. Dec 27, 2016 at 8:32 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    What brand spacers are those? Do the instructions make any mention of how far the lugs should go down?
    That seems a little sketchy to me.
  15. Dec 27, 2016 at 8:35 AM
    cbell92129
  16. Dec 27, 2016 at 8:50 AM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    These are 1 inch Bora spacers. I've had them on for 3,500+ miles with no issues. You can see I have about 2 threads showing beyond.
    Per the instructions everything was torqued, I took it for a 5 mile test drive. Re-torqued everything and mounted the wheels back on. So far I've done a tire rotation and just swapped on the winter wheels and tires. Re-checked the torque on everything again with no issues. Every time you do a tire rotation its good measure to re-check the torques. Generally no need for blue loctite. Just remember not to use an impact gun since that will generally break the studs.
  17. Dec 27, 2016 at 8:50 AM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    As said before, the SpiderTrax lug nuts go all the way with a bit of the original bolts passing through the lugnut. I'm not sure I'd be comfortable with only partial threading like that picture shows and I'm a fan of spacers. I've run spacers on both trucks and cars for years and never had a problem but I've never had spaces that didn't bolt all the way through. I'd call the manufacturer and make sure these are the correct spacers for your truck.
    Krazie Sj likes this.
  18. Dec 27, 2016 at 8:51 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Maybe try extended length lugs?
  19. Dec 27, 2016 at 8:52 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^Agreed. That does not seem like enough thread to be safe.
  20. Dec 27, 2016 at 9:12 AM
    cbell92129
    Thanks for all the feedback, much appreciated
