Front Speaker depth question
Discussion in 'Audio & Video' started by 2chains, Apr 8, 2011.
  1. Apr 8, 2011 at 8:38 PM
    2chains
    2chains [OP] Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    Did a search around the site but can't find exact answer. Looking at buying 6.5" front speakers, depth is 2.75". Will this fit in factory door opening without hitting anything in the door? Will it be easier to buy or build speaker mount, what thickness would be best. Any advice would be appreciated, I'm a total noob when it comes to audio stuff!!
  2. Apr 9, 2011 at 12:33 AM
    Eurosport
    Eurosport Well-Known Member
    around the world
    clearance i think it's 3.25-3.5 so 2.75 is good to go...
    thickness on the mounts is usually 3/4 of an inch, there's some options you can get the scosche adapters (plastic), you can make your own mdf ones, you can get ********* ones (hard plastic or mdf options), or you can get mr marv's mdfs as well...
  3. Apr 9, 2011 at 4:44 PM
    tanzak88
    tanzak88 Well-Known Member
    Since you're wanting to install 6.5" speakers in a 6x9 factory location, you'll need to build a baffle anyway. You can get away with a 3/4" baffle and still have room between the speaker and door panel. With that 3/4" baffle, your mounting depth is now 2". You're good to go.
  4. Apr 9, 2011 at 5:01 PM
    2chains
    Calgary, Alberta
    thanks, for the info on this! can't wait to get started, trying to get massive audio rk6 components online!
