Front speaker question
Discussion in 'Audio & Video' started by Delrivpilot, Feb 22, 2009.
  1. Feb 22, 2009 at 6:17 AM
    Delrivpilot
    Delrivpilot [OP] Red Sox Nation
    Jonathan
    PA
    06 Double Cab
    Westin Runnin Bars, Toytec 2" spacers, TSB suspension, Cooper Discoverer ST's 265/75/16. Pionner Avic F700Bt, Wet Okole seats,spidertrax spacers
    I just had a couple of 6x9 speakers installed in the front doors. The guy told me he had to cut out the exsisting speakers and attach my new speakers to the old bracket to install the new one. Now the inside door panel does not fully clip into the door at the bottom because the speaker sticks out too far. Would it make a diff if a got the brackets from Tacotunes and changed them out?
  2. Feb 22, 2009 at 9:27 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    Authorized Hybrid Audio Technologies Dealer (www.hybrid-audio.com) ARC Audio amplifiers, subs, processors now available! Helix Processors now available! For you super high end guys Brax amplifiers will be available soon! (PICS HERE and new website coming soon with Subwoofers, Amplifiers, Wiring Kits)
    What's the mounting depth of the new speakers?
  3. Feb 22, 2009 at 10:10 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    also you may have to take off any sort of grill on the speaker. The plastic one build into the door panel is more than enough protection. Also make sure you have the door panel mounting BEHIND the upper most lip on the bottom of the window. I missed this and it causes some frustrating experiences where the door panel would clip on everywhere except the bottom.
  4. Feb 22, 2009 at 2:44 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Thanks dgerm, I am going to call the guys that installed them tomorrow. I am assuming they did take off any covers. Thanks for the sugg
  5. Feb 22, 2009 at 2:45 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Hey Marv, I believe the bottom depth is 3 11/16
  6. Feb 22, 2009 at 5:15 PM
    Mr Marv
    Marv
    You most definitely need to have the proper baffle/adapter (the way they did it is not proper!) and if that is the correct mounting depth you will probably need to trim some of the plastic on the inside of the door panel.
  7. Feb 22, 2009 at 6:14 PM
    Delrivpilot
    Jonathan
    PA
    06 Double Cab
    Would the Tacotunes baffles work in my case? I am thinking I am going to go back to the guys who installed and have them redo it
