Front speakers on 07 Tacoma
Discussion in 'Audio & Video' started by natek, Jan 11, 2008.
  1. Jan 11, 2008 at 9:36 AM
    natek
    natek [OP] New Member
    2007 Tacoma 4dr TRD sport
    Alpine head unit, 6x9 Alpine type S, 6.5 Alpine type S, 15% tint
    I just dropped off my 2007 tacome dbl cab to get a head unit and speakers installed all the way around. They said to put 6x9s up front you must cut the factory speakers out to be able to mount them without using an adapter. They charged like 105 to install them. Does anyone know if they really have to do that? and u cant use the factory speakers again.If not im goin to get my money back.
  2. Jan 11, 2008 at 11:36 AM
    Leer
    Leer Well-Known Member
    Lee
    Hilo HI
    2015 Tacoma 4x4
  3. Jan 11, 2008 at 12:39 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    Stay away from the 6x9 speaker!! If they cut out the stock one don't worry because they SUCK!
  4. Jan 11, 2008 at 12:41 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Did you say $105 for just the installation of front speakers???
    Also, get some components and replace your tweeter as well.
  5. Jan 13, 2008 at 1:56 PM
    khfactor
    khfactor Well-Known Member
    Philadelphia, PA
    07 White TRD Sport
    Pop N Lock + Hose Clamp. DTRL, AFE drop-In Dry filter, 6-1/2" Replacement Speakers, JVC HD Radio, Sam's club variety Floor mats (cheap but effective), Chrome Exhaust tip, Bed Mat from ol' Ford Ranger. As of 3/25/2020, the Odometer just turned 70K.
    Just like everyone else, I replaced the stock front speakers. I did with Kenwood 6-1/2" speakers on my 07 TRS Sport yesterday. I got them thru Crutchfield for about $50 which included adapters and wiring harness for speakers. I have the factory 6-CD radio and I do not intend to replace it, at least not yet.....
    After the new speakers (front only) have been installed, the "boom boom- iness" seemed to have vanished. I know I double checked the polarity and what not. Really, you cannot installed the front speakers wrong with the Crutchfield speaker color coded harnesses.
    See attached photo for speakers I installed. Where did the BASS disappeared to? Did anyone else have this problem?
    After I installed Kenwoods, One thing I noticed that was different from the factory speaker mount was approx. 1/8" air gap between the adapter and the metal frame. With the factory mount, it was almost a tight install where as with the Crutchfield adpater, a gap was produced. Could this have anything to do with the BASS disappearing????
  6. Jan 13, 2008 at 5:19 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    You can get some adapter rings with the screw kit from *********.com. Get the wiring kit too and it's pretty much plug-n-play. They allow you to fit a 6x9 in the front without cutting the door. The overall cost is probably the same, but you aren't cutting into your truck.
  7. Jan 13, 2008 at 7:27 PM
    bledsoe3
    bledsoe3 Well-Known Member
    Portland
    '15 DCLB Limited
    SnugTop, Air Lift bags, Bilstein 5100's up front, AAL in rear, 275/70/18 BFG AT TA KO2, URD TCAI, URD Cat Back
  8. Jan 15, 2008 at 5:33 PM
    bbarian333
    bbarian333 Well-Known Member
    SoCal
    06, Accesss Cab, TRD Sport
    TRD exh, K&N drop in,TRD seat cvrs,tsb springs
    Like robrjohnson says, use the ********* adaptor kit and you can use any speaker. I've looked at crutchfield and i dont think their adaptors work correctly with our trucks.
