Front spring difference between 4WD and PreRunner?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gzig5, Oct 4, 2022.
  1. Oct 4, 2022 at 1:25 PM
    gzig5
    gzig5 [OP] Well-Known Member
    Mequon, WI
    2002 Tacoma PreRunner 2WD
    I was under the impression that the 2002 Double Cab PreRunner and 4WD models had the same suspension components, but while looking for front springs I found that the 4WD DLX and PreRunner have different part numbers. The numbers are similar but no indication of what the difference may be. Does anyone know if there is enough of a difference in spring rate between them that is would make a difference?
    PreRunner R/L 48131AD160 / 48131AD170
    4WD DLX R/L 48131AD140 / 48131AD150
  2. Oct 4, 2022 at 1:27 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    maybe they can hold more weight in the 4x4 version since it has a front differential?
