front stock height?
Discussion in 'Suspension' started by solus, Jan 20, 2010.
  1. Jan 20, 2010 at 11:00 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I was wondering what the stock height of the front is? From the ground to the bottom of the fender...
    I have bilsteins OME 885 w/ 1/2" spacer and 285/70/17 tires and the measurements from the ground to the bottom of the fender is:
    Pass: 39"
    Driver: 38.75"
    is this more than 3 inches, not including tires? What is the stock height? 285/70/17 give about 1" over stock right?
    I just have this feeling that I'm over 3 inches not including tires
  2. Jan 21, 2010 at 12:47 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    mine was 34 1/2" on the left side and 34 5/8" on the right from the ground to the bottom of the fenders....stock
    ...so including the tires you are about 4 1/4" of lift on the left side and 4 3/8" of lift on the right
    265/65/17 or 265/70/16 is the stock tire sizes...so your tires are roughly 2" taller than a stock tire which would give you 1" more of ground clearance...so you have over 3" of lift if you don't count the tires :)
  3. Jan 21, 2010 at 6:03 AM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    i have the same measurements 39 pass, and 38.75 driver and im on billys set at 2.5 w/ toytec 1/4 spacers on both sides...w/ 285-70-17 km2's
  4. Jan 21, 2010 at 4:56 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    thanks thats what I thought
  5. Jan 22, 2010 at 1:33 AM
    kilgoja
    Alabama
    :mudding:
