front straight axle conversion?
Discussion in 'Solid Axle Suspension' started by dirty TaTer, May 9, 2011.
  1. May 9, 2011 at 6:35 AM
    dirty TaTer
    dirty TaTer [OP] Ruts are the enemy
    Kevin
    Pasco Florida
    96 2.7 3rz taco
    Doorman OEM rear leaf packs, dynomax thrush glasspack, and cool milk crates in the back B)
    I was just wondering a ball park for converting my 96 4x4 taco front end into straight axle and leafsprings. is this even a good idea in the long run as far as off road performance goes?:confused:
  2. May 9, 2011 at 6:40 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    Check out the rocksolidtoys.com/forum
    Solid axle swaps are nasty. Real expensive though
  3. May 9, 2011 at 6:43 AM
    dirty TaTer
    Kevin
    Pasco Florida
    96 2.7 3rz taco
    yea, will do
  4. May 9, 2011 at 3:40 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
  5. May 9, 2011 at 3:43 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    LOL OP the cheapest your going to be able to "do a SAS right" is about $6000 and that's doing all the fab work yourself.
  6. May 9, 2011 at 4:06 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    All pro makes a kit
  7. May 9, 2011 at 4:35 PM
    JLink
    Josh
    Ocean, NJ
    The "Big Nig"
  8. May 9, 2011 at 4:38 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    You can do it for about 1500.
    Not really if you read that anywhere or hear someone telling you that then they are bs'ing. 6 grand is about the cheapest it can be done
  9. May 10, 2011 at 8:07 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    pff who needs SAS with Land Cruiser front diff 35 splines :D
  10. May 10, 2011 at 8:10 AM
    03taco
    03taco Well-Known Member
    someplace
    03 tacoma lifted 6in on 35s
    fabtech 6in lift, 35.12.50.16s,on mt classics
    you can peice them together and do all your own fab work it can be relet. cheap now by cheap im talking 5-7 grand
  11. May 10, 2011 at 8:15 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    but yes it is the best for off road crawling! most flex!
  12. May 11, 2011 at 6:08 AM
    awsumdc
    awsumdc Well-Known Member Vendor
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    Come check out this site.
    Lots of cool toys here. RockSolidToys
