Front strut assembly for double cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by DW04, Apr 27, 2018.
  1. Apr 27, 2018 at 6:08 PM
    DW04
    DW04 [OP] Member
    Baton Rouge
    04 PreRunner SR5
    I have a 2004 pre-runner V6 double cab. Does anybody make a front strut assembly for a double cab?
    I found several online but they all specify only regular and extended cab. The only ones I find for double cab are strut only, not the assembly.
    thanks
  2. Apr 27, 2018 at 7:48 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Same strut for single cab, xtra cab, double cab and 3rd gen 4runner
  3. Apr 27, 2018 at 9:08 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    You can use any quick strut assembly. They all fit physically. I'd pick one from a 4wd extended cab. The spring rate would probably be similar to your prerunner double cab.
  4. Apr 28, 2018 at 4:54 AM
    DW04
    DW04 [OP] Member
    Baton Rouge
    04 PreRunner SR5
    Good point about the spring rate. Thanks guys.
  5. Apr 28, 2018 at 8:35 AM
    DW04
    DW04 [OP] Member
    Baton Rouge
    04 PreRunner SR5
    I looked at the specs of the recommended shocks on the Monroe website and while the strut assemblies may all be the same size, the shock that goes in them vary greatly.
    The 71351 is used on the 4wd base double cab and the rwd pre-runner double cab (mine). Model 71352 is used on the 4wd base regular and extended cabs, the rwd pre-runner regular and extended cabs. Model 37111 is used on all rwd base models regardless of cab.
    As the image shows, the compressed, extended and travel lengths vary by a fairly wide amount. If i pick the 71352, the extended length and travel are about 2" longer than what i have now. Is this a bad idea? Will it work fine? Any suggestions?
  6. Apr 30, 2018 at 7:47 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    The new linear rate springs I put in the front of my DC were actually a bit shorter than original TRD progressive springs. They were advertised as stock height, and they were after fitting. To say this- length of spring doesn't matter a whole lot when determining ride height. If they advertise them as stock replacement, they are going to be really close.
  7. Jun 15, 2018 at 6:18 PM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    What did you do and how did it turn out?
    I am considering "Monroe" for a stock replacement... any thoughts? I can purchase for much less than the "stock Bliestein " Strut/shock....
  8. Jun 15, 2018 at 6:39 PM
    DW04
    DW04 [OP] Member
    Baton Rouge
    04 PreRunner SR5
    From what I read here in many posts, the Monroes are not high quality so I passed on them. I bought a set of the Bilstein 5100s from Wheeler's Offroad and some Moog 81082 front springs along with new top plates, stem cushions and washers. I found a local shop who assembled them for $30 and installed them myself.
    I never owned the truck new so I don't have anything to compare against, but now the ride is noticeably quieter & smoother.
    dborrer likes this.
  9. Jun 15, 2018 at 7:02 PM
    dborrer
    Mr. Dan
    St. Augustine, FL
    Interesting.... how hard was that to install? I've watched a few videos....
    Thanks
  10. Jun 15, 2018 at 7:20 PM
    DW04
    DW04 [OP] Member
    Baton Rouge
    04 PreRunner SR5
    It was actually pretty easy to install. I probably should have watched a video or two. It took me an hour to figure out how to get one rear shock on. Once I figured out that you had to use a bottle jack between the leaf spring and frame to force the rear down enough to get the lower shock bolt to line up it was a piece of cake. I needed the bottle jack to push down the upper control arm to get the strut assembly in as well. Altogether I probably spent 2 hours on it.
    dborrer likes this.
