front strut assembly
Discussion in 'Suspension' started by motorhead310, Feb 17, 2014.
  1. Feb 17, 2014 at 5:20 AM
    motorhead310
    motorhead310 [OP] Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    So I bought the OME 881 springs and the nitrocharger shocks from 2 different dealers (I got a better price by shopping around). What else do I need in order to put this setup together and ready to install? I saw Toyotec sells a shock bushing kit. Do I need this. What about the top plate (I think thats what its called)? Where do I buy it from? I would like to set up the shocks and coil to save time when I install. Otherwise I would have to remove my current stock setup, and then take it to a mechanic to seperate the shock from the coil, and have him assemble the new one.
  2. Feb 17, 2014 at 5:26 AM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    From what I've read most people do the latter - take it to shop with spring compressor. But I believe that you can buy the top plate online from toyota part websites, not 100% sure though. Wheeler's offroad might also carry them, I know they said they had 2nd gen ones a while ago(1st+2nd gen have same top plate maybe?)
  3. Feb 17, 2014 at 5:31 AM
    motorhead310
    Pomona , Ca
    Thanks for the quick reply. I wanted my shock and coil ready to go so I simply swap them when its time to instal. Depends on how much the top plate cost new.
  4. Feb 17, 2014 at 5:34 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    the top plates are real expensive. Last time I looked they were $50/each. Might just find someone selling the whole unit off of a stock truck and swapping them out
  5. Feb 17, 2014 at 5:38 AM
    motorhead310
    Pomona , Ca
    Looks like a new pair of top plates costs $50. That will pretty much wipe out the reason I searched for hours and hours trying to get the best deal and bought the shocks and coils seperate. Are there any rubber bushings or anything similar that will need to be replaced when I assemble the new coil and shock?
  6. Feb 17, 2014 at 6:39 AM
    MTopp
    05 SR5 4x4
    The parts that go on top of the strut in part 13 in this diagram are typical ones that people replace - that said, from this diagram it doesn't look like you can buy them separate so I'd re-use old ones if possible - Might need part 15(coil isolator)
  7. Feb 17, 2014 at 9:11 PM
    motorhead310
    Pomona , Ca
  8. Feb 20, 2014 at 7:23 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    I just bought a set of top plates for my 03 2.7L from RockAuto.com
    Here is what they have for your 01 Pre-Runner. There are all going to be about the same quality.
    2001 TOYOTA TACOMA 2.7L L4 DOHC : Suspension : Strut Mount
    MONROE Part # 904900 Strut-Mate Strut Mounting Kit. One of our most popular parts. Front
    $15.57
    MOOG Part # K160030 {#4860935010}
    $27.89
    SACHS Part # 802439 {#4860935010} Quantity per Axle: 2; Strut Mount and Bearing. Front; 4WD; w/o HD Upgrade (Only 13 Remaining)
    $31.99
    RAYBESTOS Part # 5201469 Professional Grade
    $45.79
  9. Feb 20, 2014 at 7:49 PM
    MTopp
    05 SR5 4x4
