Front Strut Assy
Discussion in 'Suspension' started by Saltcodnewfie, Jun 13, 2017.
  1. Jun 13, 2017 at 6:59 PM
    Saltcodnewfie
    Saltcodnewfie [OP] Member
    larry
    Hi
    I've looked at several aftermarket front strut assy's for my 2010 Tacoma 4WD.
    I'm trying to determine what is the correct (and minimum) length of the upper mounting studs on the front struts ? and are the left and right side the same ?
    I've seen some with 1" studs and others with 1.5" ; I'm not sure if the 1" would be long enough ?
    My truck has stock struts and the studs appear to be longer than 1" , but its difficult to get a good measurement without removing them.
    thanks
