Front struts help
Discussion in '1st Gen. Tacomas (1995-2004)' started by T12DELAY, Feb 7, 2020.
  1. Feb 7, 2020 at 11:23 PM
    T12DELAY
    T12DELAY [OP] Active Member
    Oregon
    2003 Tacoma | 2.7L | SR5 | 4 Cylinder | 2 Years of ownership
    1 fixed part = 2 broken parts
    quick question, as I'm slowly trying to revive my Taco i was wanting to replace the old struts in the truck for a better ride, what are some good reliable struts either from experience or from word of mouth you've seen? i got a 2.7L '03 4 Cylinder if that helps with any ideas
  2. Feb 7, 2020 at 11:37 PM
    T12DELAY
    Oregon
    lol i realized i could easily just type in "5100 struts" and boom i got my answer xD so i figured there was no point in me asking that question
  3. Feb 7, 2020 at 11:40 PM
    T12DELAY
    Oregon
    one question i do have is if you used these, how did you go about getting the springs off if i was gonna re-use the old springs?
  4. Feb 7, 2020 at 11:47 PM
    T12DELAY
    Oregon
    lol yea, would an assembly kit be a good idea? where it comes with new springs almost like a ready to install method? or are there cons to doing that
  5. Feb 7, 2020 at 11:54 PM
    T12DELAY
    Oregon
    yea for sure, im not really on a budget really, just timing it with paychecks coming in lol otherwise yea ill prolly go with an assembly kit
    whatstcp[QUOTED] likes this.
  6. Feb 7, 2020 at 11:58 PM
    T12DELAY
    Oregon
    sounds good, thanks for the help
  7. Feb 8, 2020 at 1:48 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Some tips from a guy who fucked around with 5100 and has gone through a set. Have someone else build your struts ideally @Wheeler's Off-Road Inc will set you up right. I had to deal with stupid bushing issues and non oem top hats list goes on. For the amount of money I spent i could have had a set of Kings or close to it.
    but now that my 5100 are set correctly I like them.
    whatstcp likes this.
  8. Feb 8, 2020 at 9:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well OP didn't say what kind of better ride he was looking for :notsure:
    You offered sound advice with suggesting 5100s
    The Bilsteins will actually provide a firmer than stock ride, as they are oriented towards off road performance. If off roading is what the OP will do, then the Bilsteins are a quality yet budget friendly setup.
  9. Feb 8, 2020 at 10:24 AM
    T12DELAY
    Oregon
    cool thank you, im just looking for a smoother ride because the area i live in has a lot of dips and pot holes in the roads and the old struts are making it a bumpy ride to and from work is all but im good with the 5100's unless you got any other suggestions
    GQ7227 likes this.
  10. Feb 9, 2020 at 11:29 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    do these 5100s require a lifted to a stock height 1st gen truck
    i am needing to get some replacements shock absorbers up front ... on original equipment still
    with these 5100s i now have 4 choices of which to make from and not sure which is going to alleviate bad roads issues and be happy driving once again
    i would like to get these taken care of before those holes here locally start really expanding like craters, saw a few this morning popping up
  11. Feb 9, 2020 at 1:44 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @T12DELAY , if your not looking to lift your truck, and want to keep the stock ride height take a look at the Bilstein 4600 shocks. They'll give you decent performance, without going through the hassle of lifting the truck. Jut my 2 cents worth.
    GQ7227 likes this.
  12. Feb 9, 2020 at 2:05 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are those for the front, rear or both
  13. Feb 9, 2020 at 2:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    4600s are stock length, and a tad bit softer than 5100s
    They are what Toyota uses on these trucks; they're the yellow bodied Bilsteins
  14. Feb 9, 2020 at 2:22 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @GQ7227 , I purchased a complete set. I'm pretty sure there's a difference between the front and rears, You can always go to wheelers website or any 4 wheel parts web site, and find the answers your looking for. Someone else might chime in with the correct information.
    GQ7227 likes this.
