Front struts interchangeable?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Howlinhopper, Jul 16, 2016.
  1. Jul 16, 2016 at 10:38 AM
    Howlinhopper
    Howlinhopper [OP] New Member
    1998 Tacoma 4-wheel drive
    I have a 1998 Tacoma extended cab 4-wheel drive. I suspect my mechanic recently installed the front struts kits on the wrong side... Left on right & right on left. If so, is this a problem or are they interchangeable?
  2. Jul 17, 2016 at 10:03 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I think they can go on either side. There is an orientation to the coils to seat into the top and bottom of the shock.
    Just curious..what lead you to think they were installed on the wrong sides?
  3. Jul 17, 2016 at 4:43 PM
    Howlinhopper
    Have rubbing sound on left side that wasn't there before. Thank you for your reply & question.
  4. Jul 17, 2016 at 5:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Can you better define what you are referring to. What exactly is new?
    Is it just the shock absorber portion of the front coilover assemblies? Or is a complete coilover? Meaning the coil spring and shock absorber combination? What is the brand of your new "strut"? Is it an OEM stock replacement or did it also give you some additional lift.
    Are the tires and wheels new too?
  5. Jul 17, 2016 at 8:27 PM
    otis24
    Mark
    California
    Interesting.
    Can you see any signs of rubbing? Like a surface that has had the dirt/dust removed due to rubbing.
  6. Jul 17, 2016 at 8:51 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    I think the springs are left/right specific, but the strut (shock part) is universal.
    otis24 likes this.
  7. Jul 17, 2016 at 10:14 PM
    otis24
    Mark
    California
    Edit: I'm thinking of my old man emu coils. Stock coils or whatever you have might be different.
  8. Jul 18, 2016 at 2:42 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    I recently put coil over assembly's on my 2004, and they have different part numbers left and right
  9. Jul 18, 2016 at 3:28 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    One is left, one is right.
  10. Jul 18, 2016 at 10:23 AM
    Howlinhopper
    Digiratus, thank you for taking the time to provide such a comprehensive reply. The struts were the complete assembly units with coil & shocks combined. They are not OEM but I got them through a Toyota dealership... the brand is Monroe. There was no lift done and the tires wheels have been on the truck for 4 years. Visually, there is no sign of rubbing or scrapped paint evident. I tried spraying WD-40 around the bottom bolt and top mounting area. Is there a grease fitting somewhere I'm not seeing?
    Once again, thank you all in advance for your replies.
  11. Jul 18, 2016 at 10:39 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I have no personal experience with the Monroe brand pre-assembled coilovers. However, I would think if Monroe designed them to be side specific, each would have a unique part number. This is probably something you should ask about at the place of purchase. Does the invoice list more than one part number?
    Can you better describe the sound. For instance, is it constant at all speeds or is it intermittent? Or does it vary in intensity with wheel speed?
    FWIW, sounds and vibrations are very hard to diagnose via the web.
  12. Jul 18, 2016 at 11:24 AM
    Northern Taco
    I put those exact Monroe assemblies on my Tacoma, they are side specific for a reason, have them changed. I would imagine you're alignment is out of whack as well
