Front Sumos Super Thread
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheRedComet, Aug 21, 2021.
  1. Mar 5, 2022 at 8:19 AM
    #321
    Hawk1
    Hawk1 Active Member
    Installed these on the front of my 2021 OR DCLB. I jacked up the front and still needed to cut off about an inch or maybe less of the bolt to get them to go in. Otherwise it was super easy. I hacksawed off the approximately 3/4" of the bolt with the nut all the way threaded then filed the cut off end then ran the nut up and off to make the threads. Nuts come in the box even though Tacomas don't need them.
    JGO and Cowdog like this.
  2. Mar 5, 2022 at 10:41 AM
    #322
    Twitch57
    Twitch57 Well-Known Member
    N AZ
    2021 DCSB SR 4x4
    Yup, took me about 20 mins, and most of it was figuring best way to reach it and pulling out the lights.
    Only tool needed is wrench to remove old bump stops and wrench to install the sumos.
    It wont really lift the truck, but it will smooth out the ride and reduce body roll.
    Cowdog[QUOTED] likes this.
  3. Mar 5, 2022 at 11:01 AM
    #323
    Cowdog
    Cowdog Well-Known Member
    So they don't make constant contact on a stock sr5? Thanks.
    I do a lot of towing, but I don't see how they will help with that.
  4. Mar 7, 2022 at 5:39 AM
    #324
    Plain Taco
    Plain Taco Well-Known Member
    VT
    I’m not sure, been wondering the same.
    I’m thinking of adding the Roadmaster active suspension to mine. I’ve read that it lifts the back 1 inch plus. Would Sumos in the front help level it or not? Anyone know?
  5. Mar 7, 2022 at 6:06 AM
    #325
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    The front do make constant contact on my 18 TRD OR. I can tell there is a very slight lift because of how the front tracks the road. I need to get an alignment now.
  6. Mar 7, 2022 at 7:47 AM
    #326
    Twitch57
    N AZ
    2021 DCSB SR 4x4
    They do make contact, barely noticeable lift, to the point it might be a placebo effect
  7. Mar 7, 2022 at 11:07 AM
    #327
    Cowdog
    My next question is is the ride stiffer than I was back when I used to watch Bay Watch or Golden Girls? How will these help with towing? Thanks!
  8. Mar 7, 2022 at 8:25 PM
    #328
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Im not impressed with the rears. If I was towing I would go with air bags. I had air bags on my 2nd Gen and it rode way better loaded then these sumo springs. The sumo springs have a lot of rebound effect. They do help on big bumps with my dirt bikes in the back, but they rebound so much. I’m considering removing them and getting air bags.
  9. Mar 9, 2022 at 2:35 AM
    #329
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have 5100s on my truck with the front set on the 4th perch, the rear on a 1 inch block and run the blue Sumos front and rear. Mine do not make contact front or rear. I think it made speedbumps or potholes a whole lot smoother, also some gravel roads are no where near as bad. I don't tow anything but I swear mine rides better. May have something to do with my truck having a slight lift and the bump stops not touching which allows the shocks to do their job until the bump stops are hit. I have been lifted for 3 1/2 years and on the Sumos for about 6 months, I can say my ride is better.
    stealthmode likes this.
  10. Mar 9, 2022 at 7:54 AM
    #330
    Cowdog
    Can anyone tell me how/if front sumos help with towing? Thanks
  11. Mar 9, 2022 at 7:59 AM
    #331
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    Someone correct me if im wrong.. but I think the front ones are intended to smooth out harsh bottom outs in the front not really for towing.
    Cowdog[QUOTED] and RandomHero01 like this.
  12. Mar 9, 2022 at 9:22 AM
    #332
    Twitch57
    N AZ
    2021 DCSB SR 4x4
    That is my understanding as well.
    They smooth out felt bump in the road and reduce body roll.
    I suppose making the truck more stable would make your towing experience better, but I am unaware of any specific / intentional impact
    Cowdog and Jimmy92870[QUOTED] like this.
  13. Mar 9, 2022 at 9:24 AM
    #333
    Jimmy92870
    Texas (DFW)
    07 DCSB PreRunner
    Makes sense.
    Cowdog and Twitch57[QUOTED] like this.
  14. Mar 28, 2022 at 5:19 PM
    #334
    Josp
    Josp Member
    21 DCLB SR5
    Stock SR5. Full contact in front, 3/4” clearance in rear when empty.
    Reduced body roll.
    When towing, the rear only dips about an inch and really smooth over concrete joints.
    I don’t think the fronts help per se in towing, but the rears sure do.
    The fronts help the body roll, and handling.
    JGO likes this.
  15. Apr 6, 2022 at 7:30 AM
    #335
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    What's the best way to install the fronts on a stock truck? Can I do it without taking my wheel off if I jack up the truck?
    Thinking:
    1) Jack up truck from front, center, jackpoint.
    2) when truck is in air, turn wheels, then simply swap bumpstops?
    Thanks.
    hyrule_trd likes this.
  16. Apr 6, 2022 at 7:39 AM
    #336
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Yea pretty much, some in this thread have cut some of the threads off to help since you’ll only get so much room.
  17. Apr 6, 2022 at 7:49 AM
    #337
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    I just jacked up one side at a time. I was able to remove the stock bumps and install the new Sumos without removing the wheels and didn't need to cut the bolt on the Sumos. My Tacoma is a stock height OffRoad.
    JackJoachim[QUOTED] likes this.
  18. Apr 6, 2022 at 9:52 AM
    #338
    Twitch57
    N AZ
    2021 DCSB SR 4x4
    X2
    jack up truck frame one side at a time. Did not have to remove the wheel
  19. Apr 15, 2022 at 8:52 AM
    #339
    JackJoachim
    Jack
    North MS/Memphis
    Just did the install on the fronts. I had to cut threads to get them to slide in there. The results are exactly what I wanted, less brake dive and I think I gained some lift up front. No complaints.
    grogorat and Twitch57 like this.
  20. Apr 22, 2022 at 12:33 PM
    #340
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    Well finally got them installed. Had to cut the threads down so that they would slide in there. Had the whole front lifted up and the front tires off to make it easier on myself. Based on my experience, not sure how anybody with the stock suspension can get them installed without trimming the threads. Timing is everything though. Just got done and pulled it out of the garage and had a call for an elevator rescue at the local high school. Of course as usual, when we got there the students were out, but we were not advised. Got to love it.
    grogorat and Jimmy92870 like this.
