Front suspension advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Globemaster, Dec 31, 2017.
  1. Dec 31, 2017 at 10:41 AM
    Globemaster
    Globemaster [OP] Well-Known Member
    17 DCLB TRD OR
    OVTUNE 91 1.04 255/85/16 ST MAXX FOX 2.5 ext travel ICON billet UCAs OME EL095R
    TW,
    I’m looking for some advice on front suspension. I have read a ton of forum posts on suspension but can’t find exactly what I am looking for.
    Current setup: 17 DCLB OR, front is stock. Rear has fox from a TRD PRO. Tires and rims are stock.
    Goal: level truck, and increase performance to match the rear suspension. Ie a new coilover setup not a spacer kit.
    Future tires: 255/85 r16s (Cooper st max). On stock OR rims.
    I may run Dakar or something similar in the rear someday due to a camper shell. No plans for a new front bumper or extra weight up front.
    Thanks!
  2. Dec 31, 2017 at 10:56 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I accomplished what you are asking by just using 5100 shocks and a single Dakar AAL, but definitely call Marie at Headstrong off-road for your answer.
    Globemaster[OP] likes this.
  3. Dec 31, 2017 at 11:04 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    You are on the right track, go with a set of extended travel coil overs and aftermarket upper control arms. Fox is my brand of choice; King, Sway-Away and several others all make good products.
    Unless you frequently reach the limitations of your front end droop and it is a problem (not maintaining contact with the ground / traction) I would highly consider one of the aftermarket UCAs that utilizes a ball joint instead of a heim. Heims, although stronger and having more articulation, wear out much faster than ball joints. The purpose of the UCA is to change the geometry to adapt to the increased ride height - such that you can still get appropriate camber and caster for alignment.
    In reality your front end is already out performing your rear end. Those Fox shocks back there can only do so much when still in the stock geometry (limited bump travel). Dakars might give you a little more bump travel, but not much. What they will do is keep you from sagging when you load the bed down, which does eat up bump travel.
    2016Tacoman and Globemaster[OP] like this.
  4. Dec 31, 2017 at 11:15 AM
    Globemaster
    17 DCLB TRD OR
    I will be calling her this week when she is back in the office for sure!
  5. Dec 31, 2017 at 11:16 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Fox
    More $$ though.
  6. Dec 31, 2017 at 11:27 AM
    Globemaster
    17 DCLB TRD OR
    I am looking at the 2.5 without resi vs 2.5 with. I just want to make sure I can get level with either.
  7. Dec 31, 2017 at 11:33 AM
    OnHartung'sRoad
    2.5 inches? Yeah, you will need a coil over and a whole leaf pack, I just went with 1.5” and a single leaf with which the 5100’s work well, but not for 2.5”. Marie can suggest a few shock options for the extra height and price range you want.
  8. Dec 31, 2017 at 11:37 AM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    resi or non-resi, they're both the same as far as height adjustability goes.
  9. Dec 31, 2017 at 11:37 AM
    Globemaster
    17 DCLB TRD OR
    Sorry I mean fox 2.5 coilovers, not necessarily 2.5 lift
  10. Dec 31, 2017 at 11:37 AM
    OnHartung'sRoad
    Ah :)
