Front suspension advise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Coopsdaddy, Dec 19, 2024.
  1. Dec 19, 2024 at 10:45 AM
    Coopsdaddy
    Coopsdaddy [OP] Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Ok I’m going to do new jba uca,6112 shocks and Ecgs bushing.
    Just so I don’t go backwards what order would you do this in?
    I know I can just get after it,I just want to not cause myself more work.
  2. Dec 19, 2024 at 10:50 AM
    BabyBilly
    BabyBilly Well-Known Member
    Billy
    2020 TRD
    Get everything apart, then pull the CV axle do to the ECGS bushing.
    Do you have the ECGS bearing puller tool? Did you already get new UCA bolts or are you going to try and re-use the ones in there now? It's a lot easier to just cut out those bolts and replace them backward instead of bending up your inner fender sheet metal to remove them.
  3. Dec 19, 2024 at 10:50 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    My order of events would be ECGS, UCAs, Shocks.
    BabyBilly likes this.
  4. Dec 19, 2024 at 12:41 PM
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Have the ecgs tool for bearing and seal.
    I do not have the bolts but could see if local dealer has them.
  5. Dec 19, 2024 at 12:53 PM
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Local dealer 50 miles has a few 24.00 each.
    If it’s worth it I’ll pick some up.
    BabyBilly and wmb67 like this.
  6. Dec 21, 2024 at 6:45 AM
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Just removed mine from my 2012.
    Not hard to do at all.
    Will not be buying new bolts.
