Front Suspension Clunking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by {WBK}Viper, Aug 13, 2018.
  1. Aug 13, 2018 at 2:46 PM
    {WBK}Viper
    {WBK}Viper [OP] Active Member
    Herriman, Utah
    2015 TRD-Off Road DCSB
    So, I know this has been a thing for a lot of people and I've tried every fix that I can find, but nothing has worked so far. Here's the deal:
    I have a 2.5" Icon stage 1 lift with SPC UCAs. The noise started about 4 months after putting the lift on. 2015 OR DCSB.
    When I start/stop, or the suspension moves over bumps at low speed it clicks/clunks/pops etc. on both the left and right of the truck (pass side is worse). It is most noticed at low speeds, like around parking lots. Kinda sounds like the Absent minded professors Model T haha
    I took it to the company that put the lift on and they swapped out the swaybar end links. Nope.
    Checked the brake pads...nope they don't make any noise.
    They checked and double checked the UCA's and all the bolts. Tight as can be. They said there was some movement in the LCA's at the bushings and they think that's the noise.
    I wanted a second opinion so I went to toyota. They said it was the UCA's for sure. I asked them about the LCA's and they said they often have movement in them and that was not where the noise was coming from. I went back to the company and we swapped out the ball joints under warranty in the SPCs and that did not fix the problem....So I have three choices at this point.
    1) live with it.
    2) try to change the LCA bushings which is a $500-600 job.
    3) part out and sell (not joking)
    The only thing I can think of is that the Icons are making the noise, but you can't see them moving and the only way to tell is to replace them to see if that works.
    Anyone have any other suggestions? I, and it seems every mechanic I go to including Toyota is at a loss.
  2. Aug 13, 2018 at 2:48 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    What skid plate are you running?
  3. Aug 13, 2018 at 2:48 PM
    {WBK}Viper
    Herriman, Utah
    No skids. That was in the works.
  4. Aug 13, 2018 at 2:52 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Just checking. My skid plate clunks a lot, but it's a Pelfreybilt. Seems the frame twisting causes it to shift and pop. But that's not your issue.
    Only other thing I can suggest is to make sure you torque the UCA bolt when the truck is sitting on the ground, not hanging in the air and to check the LCA bolts are tight and that LCA bushings or lower ball joints could be the problem.
    Could be the sway bar hitting the coils, that's been known to happen.
  5. Aug 13, 2018 at 3:08 PM
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
    Im having the same issue. Ive got SPC uppers also. Going to replace the LCA cause Ive got 180k on them. Everything seems tight but Im tired of diagnosing and chasing. Ive got the bilstein 6112s. I dont think its the sway bar hitting the strut cause Id have marks from them
  6. Aug 13, 2018 at 3:48 PM
    ask
    ask Member
    SF Bay Area
    Any update after replacing LCA bushing? I have similar setup and klunk.
  7. Aug 13, 2018 at 3:53 PM
    Ryan.S
    Ryan.S Well-Known Member
    09' Access Cab, 6 spd
    Similar clink here hahaha
  8. Aug 13, 2018 at 4:00 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I got clunking after I removed the brace in front of the sway bar (so I could remove the sway bar itself). It would move slightly when the frame would twist.
    Also got another clunk after I removed and reinstalled the transmission, it ended up being the crossmember that did the same thing... moved around when the frame twisted.
    A re torque fixed both issues
  9. Aug 13, 2018 at 4:02 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    You eliminated bad hub bearings as a cause?
  10. Aug 13, 2018 at 4:55 PM
    RecklessTLS
    Rowdy
    I havent got to it yet. I have to get a new front cam since mine is seized. Im also going to install the total chaos cam tab kit since I wheel mine and its all apart
    I have thought this myself but they seem to be tight. Any suggestions? Im used to the old style of bearings instead of the unit bearing. Would I need to unbolt the CV to check for free play?
  11. Aug 13, 2018 at 10:20 PM
    David K
    I had a clunk clunk clunk in my front end... it was the driver's side hub. My mechanic is Speed Freek here on TW (in San Diego County) and the hub assembly came from BamaToy1997 (in Florida). It all worked out perfectly and no more clunk! Any mechanical questions please ask them.
  12. Oct 11, 2019 at 1:20 PM
    Tech55
    Tech55 Member
    Russ
    2007 Tacoma SR5 Pre-runner
    Pioneer In-Dash Nav Radio with front and rear Camera
    A lot of tacoma owners have reported this clicking noise and some have said it is coming from the aluminum brackets on the front bumper which might have a hairline crack and clicks when the frame twist ever so slightly. My truck has just started doing this and it is a 2007. Feedback welcomed.
  13. Oct 11, 2019 at 2:07 PM
    Fish Taco 4x4
    Fish Taco 4x4 Well-Known Member
    NC
    2013 TRD OR
    265/70/17s
    Mine started popping on the drivers side after an alignment. Figured they didn't tighten it all down to spec but when I redid my suspension and retorqued, it was still there. For me I've narrowed it down to my LCA bushings that have gone bad. I would take a look at that and also make sure everything is torqued to spec up front.
  14. Oct 11, 2019 at 2:14 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    For what it’s worth place your hand on the fender above the wheel opening and push forward and pull back. Turns out my fenders were loose and clunking
    budman1627 likes this.
  15. Oct 11, 2019 at 3:35 PM
    FJ to Taco
    FJ to Taco Well-Known Member
    Tony
    Lacey, Wa
    2015 DCSB 4x4 TRD Off Road,Snugtop Rebel
    Bilstein 5100's all around, OME 885's and OME Dakar CS047R Leaf Packs. Snugtop Rebel, pet screens,front slider drop down window. WeatherTech mats. Interior LEDS
    Jason (speedfreak) is the man ! He knows his stuff! He put on my suspension lift did my BMC and my pinch welds. Great guy to do business with!
    David K[QUOTED] likes this.
  16. Oct 11, 2019 at 4:27 PM
    JoshS
    JoshS Well-Known Member
    Josh
    2014 Tacoma TRD Sport DCSB 4x4
    Having this issue too on my passenger side only. Will post when I figure out the root cause. I did notice a slightly larger panel gap on the passenger side below the headlight like it was sagging
