Front Suspension Constantly Hitting The Bump Stops
Discussion in 'Suspension' started by zomg, May 12, 2011.
  1. May 12, 2011 at 3:24 PM
    zomg
    zomg [OP] Well-Known Member
    NOLA
    08 PreRunner SR5
    TRD CAI, Ultra-Gauge, All Weather Floor Mats, Rear Spring TSB, Avid Offroad Sliders, Spidertrax, Dynomax Superturbo, Bolt-on Grille
    Hello all,
    This morning I locked my steering wheel as far to the left as possible because of an odd parking space. I noticed that my front suspension appears to be hitting the bump stops very often. I have a totally stock SR5 suspension & only drive on the street, for now. 90% of the streets in New Orleans are positively 3rd world, but it seems to me that the bump stops are getting much more of a workout than they should. Is it normal for the front suspension to have such a limited amount of travel? The front end does not seem to be sagging any. Is there anything I can do to remedy this? The only lift I have planned is the 5100s set at 2.5 with a 2" rear AAL.
    Thanks for the help.
  2. May 12, 2011 at 3:39 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Since your truck isn't sagging, shocks blown?
  3. May 12, 2011 at 3:46 PM
    zomg
    NOLA
    08 PreRunner SR5
    I don't see how they could be blown. I just broke 20,000 miles on them. They don't appear to be leaking, but I haven't really checked them up close.
  4. May 12, 2011 at 4:18 PM
    MadTaco461
    CA
    Kinda stock
    it just seems weird for street driving to bottom out. You have bilsteins up front?
  5. May 12, 2011 at 4:20 PM
    zomg
    NOLA
    08 PreRunner SR5
    Nope, the stock black ones. Tokico makes them I think.
  6. May 12, 2011 at 4:24 PM
    MadTaco461
    CA
    Kinda stock
    sometimes factory shocks are junk. yeah get the 5100s up front. you'll be very satisfied with them.
  7. May 12, 2011 at 4:32 PM
    zomg
    NOLA
    08 PreRunner SR5
    So, I am not crazy. In your opinion, the only reason that the bump stops should be contacting the lower A arm would be if I was off road on a regular basis?
  8. May 12, 2011 at 4:38 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    yeah you should never hit the bumps on a road unless you his like a railroad crossing and jump it or something
  9. May 12, 2011 at 7:19 PM
    zomg
    NOLA
    08 PreRunner SR5
    OK, so if I add the 5100s & increase them to either 1.75" or 2.5" will that translate into more inches between the A arm & the bump stop? Also, if I set the 5100s to 1.75", but want to change them to 2.5" after I get the rear AAL are they adjustable without removing them?
  10. May 12, 2011 at 7:56 PM
    zomg
    NOLA
    08 PreRunner SR5
    OK, thanks for the help, everyone.
  11. Mar 29, 2015 at 11:28 AM
    cguernsey7
    cguernsey7 New Member
    Collin
    Texas
    Prerunner TRD sport SR5
    Plasti dip American outlaw Hollywood wheels 6 inch stage 1 pro comp lift 285x70x17 Nitto Terra Grapplers G2 Toyota tailgate
    Sorry to bring up old threads but I'm having this same problem. I have a pro comp 6" and it comes with bump stop drop brackets and it seems to be hitting every time I hit a small crack in the road. I even proved it by putting chalk on it and I could see it was hitting... I'm not sure what to do to solve this
  12. Mar 29, 2015 at 5:18 PM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    The bump stops are designed to prevent your suspension from bottoming out.
    Sounds like your extensions maybe too tall, if your bottoming out from a crack in the road.
    How much distance do you have between your extended bump stops and the frame?
    You may have to cycle your front suspension with a floor jack, and check if the extensions are the correct length (stopping travel before your suspension bottoms out).
  13. Mar 30, 2015 at 10:00 AM
    cguernsey7
    Collin
    Texas
    there is about around 1/2 inch between the bump stop and the LCA at its closest point.
    Explain what you mean cycle my front suspension with a floor jack? Not quite sure what id do there Lol. I know it should stop before it bottoms out but you would think the suspension would travel more than 1/2 inch before bottoming out right?
  14. Mar 30, 2015 at 1:04 PM
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    I can easily fit 2 fingers between the bump stops and the LCA.
    1/2 inch of clearance doesn't seem like very much...
  15. Mar 30, 2015 at 3:07 PM
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    cguernsey7,
    Just shot some video of my front suspension...even going onto a curb around town.
    Pretty boring stuff, but never saw any bump stop LCA contact.
    When I talked about cycling your front suspension, I was reffering to placing a floor jack securely under one of your LCAs and start lifting.
    If your correct, your bump-stops are going to contact the LCA pretty quickly.
  16. Oct 16, 2015 at 3:01 PM
    08FireRescueTaco
    08FireRescueTaco 08Blue_Beast
    Hunter
    Roanoke
    08 Tacoma Manual 6spd
    2008 off road 6spd manual Procomp stg 1 6in lift Allpro hd expo leaf pack 16in fuel boost wheels 315/75r16 motto trail grapples Flomaster duel 40s exhaust Doug Thorley LTH Volant CAI Relentlessfab front bumper Fox 2.0 coilovers Prinsu designs roof rack Sport hood Urd short shifter Nfab side steps Bushwacker flares
    I'm having this same issue I've been looking for shorter extensions or just getting rid of them completely since I don't do heavy off roading. Anybody have anymore info on this!?
  17. Nov 1, 2015 at 7:16 PM
    zomg
    NOLA
    08 PreRunner SR5
    I upgraded to the Bilstein 5100s set at 1.75. This mostly solved the problem unless the road is terrible. That is an actual issue in NOLA, though. There are a significant number of roads where doing the 20 mph speed limit will result in a wheel leaving the pavement. An additional change was to upgrade from stock to the Wheelers bumpstops. They are huge, but much softer than stock. I am now always hitting the Wheelers bumps, but it is much softer.
  18. Jan 7, 2016 at 5:25 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    I am having that front end noise as well on my 2015, they thought it was cab mounts. Now pointing to bump stops after my 4th visit to Toyota.
    I wasn't completely sold on what they told me but after reading this I feel a little better.
  19. Jan 17, 2017 at 9:12 PM
    Krismassie15
    Krismassie15 Member
    Kris
    Southern california
    Fox 2.5" coilovers w/reservoirs in the front with Icon 1.25" Uniball UCA's. Fox 2.0 non-resi shocks in the rear. Method NV 17" wheels, 285/70/17 BFG AT KO2 tires
    Same problem on my truck. Really annoying and ready to cut them off
  20. Jan 17, 2017 at 9:16 PM
    Krismassie15
    Krismassie15 Member
    Kris
    Southern california
    Better picture
