Front suspension install question
Discussion in 'Suspension' started by Voodoo Rufus, Mar 20, 2012.
  1. Mar 20, 2012 at 2:20 PM
    Voodoo Rufus
    Voodoo Rufus [OP] Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    I was watching this video for hints on how to install my front Icon C/Os. http://www.youtube.com/watch?v=QdyE8VkIqPg
    What is the purpose of loosening the front LCA alignment cams? Does it allow them to pivot more when the bolts from the LCA to the spindle are removed? Is the alignment messed with if loosening and re-tightening those alignment bolts?
  2. Mar 20, 2012 at 3:18 PM
    Large
    Large Red
    Link don't work but I loosened the LCA bolts that secure it to the frame so I could remove the strut assembly, and anytime you mess with your front suspension it's a good idea to get an alignment.
  3. Mar 20, 2012 at 3:19 PM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    Im not sure I didn't loosen them when I installed my coilovers
  4. Mar 20, 2012 at 5:10 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
  5. Mar 20, 2012 at 5:31 PM
    Voodoo Rufus
    Bakersfield, CA
    Doesn't seem so bad really. There seems to be so many ways to do it. Some undo the LCA, others the spindle from the UCA, or the steering tie rod from the spindle.
    All of those are just ways to make enough room to get the new CO in right?
  6. Mar 20, 2012 at 6:35 PM
    Large
    Large Red
    Correct. Although it won't hurt to drive with a bad alignment for a few miles to an alignment shop so do what you gotta do.
