Front Suspension Question
Discussion in 'General Tacoma Talk' started by cyrusrehmann, Oct 3, 2024.
  1. Oct 3, 2024 at 6:52 AM
    cyrusrehmann
    cyrusrehmann [OP] New Member
    Cyrus
    2019 Super White TRD Pro
    6 inch front 4.5 inch rear, 1.5 inch spacer, k&n intake, pedal commander, form lighting headlights, 315/75/r16 mt
    I have a 3rd gen white 2019 trd pro and Im tryna raise the front suspension more, Its on 3 inch blocks in front and rear blocks with some rough country ass shocks and then on the fox suspension which is red and I lowkey hate that shit I dont fw the red exept the skid plate so Im tryna get black struts and I already have the white uppers it gonna be tuff and I didn't know what the max i could fit in there is I was tryna cop the 2 inch leveling struts and put them on my white blocks to match but is five inches gonna fit in those uppers there supposed to be for 3.5 inch lifts and larger but they didn't say a max, idc about ride quality
  2. Oct 3, 2024 at 6:55 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Welcome to TW? Some of us are older, and occasionally using punctuation in your posts helps us avoid a possible stroke.
    To get more than 3 inches of lift you need a drop-bracket lift.
    Bandido, Mully, Finn-2187 and 6 others like this.
  3. Oct 3, 2024 at 7:00 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    This is really hard to follow. If I'm understanding correctly, you've already ditched the rear fox suspension for rough country and blocks, and are now wanting to ditch the front fox suspension (with 3" lift spacers already) for some even cheaper 2 inch leveling struts + the existing front spacers?
    I'll admit, I respect you came in here shooting us straight. You don't like red, its all for looks, and you don't care about the ride. I honestly wish more people could be this honest. While this thread will turn into a dumpster fire I'm sure for choosing rough country shocks, blocks, and spacers over TRD PRO suspension, you're bold enough to say you don't care. I respect it.
  4. Oct 3, 2024 at 7:50 AM
    frdomfghtr899
    frdomfghtr899 Member
    Keaton
    2020 Black Tacoma
    With a 5-inch lift on your 2019 TRD Pro, you're pushing things to the extreme, especially if you're already running 3-inch blocks and Rough Country shocks. Adding 2-inch leveling struts on top of the current setup may cause issues with alignment, suspension geometry, and overall drivability. While the upper control arms (UCAs) you have might technically handle up to 3.5-inch lifts, going to 5 inches may cause binding, excessive wear on the UCAs, and stress on other suspension components like your ball joints and CV angles.
    If you're dead set on getting to 5 inches, I’d recommend upgrading the entire suspension system (including stronger UCAs and drop brackets). But keep in mind, ride quality and long-term durability might take a hit. Also, make sure you get a reputable alignment done after any modifications.
    If you’re just after aesthetics and don’t care about ride quality, you could try it, but be prepared for extra maintenance and potential issues down the road.
  5. Oct 3, 2024 at 7:57 AM
    Clearwater Bill
    Billy
    Largo Florida
  6. Oct 3, 2024 at 9:24 AM
    Tacodrew22
    Tacodrew22 Well-Known Member
    Andrew
    Michigan
    2022 Tacoma TRD Off-Road
    OnX Off-Road Trail Guide. I help OnX map and document routes. I get out all across the United States but based in Michigan
    If I was trying to simulate driving down the road with the flintstones car I would do this as well…
    On a serious note your trd pro suspension for sale?
  7. Oct 3, 2024 at 10:29 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Tacodrew22 likes this.
  8. Oct 3, 2024 at 11:22 AM
    probby19
    probby19 Active Member
    Pat
    Colorado
    2019 TRD OR - 2004 SR5 5-speed 4x4
    Holy run-on sentence lol
  9. Oct 3, 2024 at 2:44 PM
    cyrusrehmann
    Cyrus
    why are all yall all uncs
    yeah i should’ve specified that im talking about the fronts i already copped the back but thanks for the info actually
    will my wear be that hella excessive in the future though?!?
    yeah if anyone wants they can buy my old suspension i still have the original shocks and i still got the struts
  10. Oct 7, 2024 at 1:43 PM
    Off Topic Guy
  11. Oct 7, 2024 at 1:46 PM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    What color is it?
  12. Oct 7, 2024 at 1:46 PM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    Im all about that red plastidipped engine cover
  13. Oct 11, 2024 at 12:21 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    WTF is an uncs? Do we remind you of a close and personal uncle? I feel offended but I don't even know why.
    I am assuming its 4wd? limited on shock overall length or will have CV axle binding.
    3" in the front is a lot, you can always do a 1" body lift to get a little more height. But a 3rd gen is already around 21" center of hub to fender from the factory, once you go above 23" it performs poorly. With a spacer lift you could be experiencing cv axle binding already, CV boot tears, coil smacking the UCA, shock bottoming out before the bumpstop is engaging. Needle Bearing issues (If not replaced with ECGS),
    Going higher is going to make these issues more prevalent and the wear and tear is going to be heading your way.
    cshrum likes this.
  14. Oct 11, 2024 at 12:27 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    This thread is as good as any to revive into a Friday thread.
    Finn-2187 and danny15l like this.
  15. Oct 11, 2024 at 1:22 PM
    danny15l
    nada
    I think he’s calling uncle effers or something
    JFriday1[QUOTED] likes this.
  16. Oct 11, 2024 at 3:17 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    nawamsayin unc?
    cshrum likes this.
  17. Oct 11, 2024 at 3:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  18. Oct 11, 2024 at 3:29 PM
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
